Coil pack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Olskooldoc, Dec 17, 2021.
  1. Dec 17, 2021 at 6:12 AM
    Olskooldoc
    Olskooldoc [OP] Member
    Doc
    Red 2015 4x4
    My truck will not start ran fine all day , get in truck to go home after work and it cranks up for one second or two then shuts off, can anyone help
  2. Dec 17, 2021 at 6:19 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Is your security light flashing in the center of the dash under the radio with the key on?
    Olskooldoc[OP] likes this.
  3. Dec 17, 2021 at 6:22 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Got gas?
    Dm93 likes this.
  4. Dec 17, 2021 at 11:54 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Cranks up for a second and dies, can be a symptom of a bad fuel pump resistor.
    The truck starts on high pressure, and then switches to low pressure “quickly” through the resistor.
    This might be worth checking.
    Chris(NJ) likes this.
  5. Dec 17, 2021 at 12:13 PM
    TnShooter
    Deogee
    STOCK
    That is actually a good suggestion.
    There has been more than one person run out of fuel with the gauge showing there is fuel.
    But I wouldn’t expect the truck to start more than a few times if this were the case.
    OP, if you want to check the resistor. It’s in front of the battery.
    See here. https://www.tacomaworld.com/threads/fuel-pump-resistor.701103/#post-24849664
    knottyrope likes this.
  6. Dec 17, 2021 at 12:30 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    my gauge was stuck wednesday night
    though the worst
    it just died on the highway after seeing Genisis in Boston.
    then i cranked it after getting to level ground and it puffed a few times, YAY
    got some gas and it started up a bit rough for a few seconds and purred again
    6 gearT444E likes this.
  7. Dec 18, 2021 at 4:33 AM
    Olskooldoc
    Doc
    Red 2015 4x4
  8. Dec 18, 2021 at 4:34 AM
    Olskooldoc
    Doc
    Red 2015 4x4
    Thanks for the suggestion I will check that out
  9. Dec 18, 2021 at 6:14 PM
    Olskooldoc
    Doc
    Red 2015 4x4
    Just wanted to say thanks brother (Dm93) took it advice, pulled the positive cable and waited 30 min , fired right up, thank you
    Dm93[QUOTED] and Steves104x4 like this.
  10. Dec 18, 2021 at 6:20 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Interesting I wonder what caused the immobilizer to stop working that a battery disconnect would fix, it should just read the chip in the key when it's inserted if the key is valid the truck should start.
    TnShooter likes this.
  11. Dec 18, 2021 at 6:30 PM
    Olskooldoc
    Doc
    Red 2015 4x4
    I've had the truck for two months, drive 3-400 miles a day and never had a problem till three days ago , what's can I check
  12. Dec 18, 2021 at 6:40 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Was the security light indeed flashing when it wouldn't start?
