Coil Packs Wont Fit On Top Of Spark Plugs
Discussion in 'Technical Chat' started by Maxola89, Sep 24, 2009.
  1. Sep 24, 2009 at 11:57 AM
    Maxola89
    Maxola89 [OP] Active Member
    Norton, VT
    2000 Tacoma 4WD Short Bed
    2.7 swap for a 2.4
    the coil packs have holes on them so you can bolt them down in the head but my head on the 2.4 does not have the threads on to bolt them down.
    what should i do?
  2. Sep 24, 2009 at 11:58 AM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    should i cut the holes off and make them fit? or is there another way?
  3. Sep 24, 2009 at 12:02 PM
    98tacoma27
    Ben
    Not Beech Creek
    Try using the valve cover off the 3rz. or you can place the packs in the valve cover and drill and tap your own holes. Do it off of the motor of course and use some sealant on the threads.
  4. Sep 24, 2009 at 12:10 PM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    if i take the valve cover off the 2.7 3rz will it fit the 2.4 2rz?
  5. Sep 24, 2009 at 12:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im pretty sure they go thru the valve cover, and bolt into the head.
  6. Sep 24, 2009 at 12:15 PM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    ya but mine wont so can i take 2.7 cover and put it on the 2.4 though
    without having any problems?
  7. Sep 24, 2009 at 12:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think you would have to change the head.
  8. Sep 24, 2009 at 12:30 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, they should be the same. The difference bewtween the 2rz and 3rz are in the block as far as I know.
  9. Sep 26, 2009 at 11:40 AM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    thanks man
  10. Sep 26, 2009 at 3:48 PM
    98tacoma27
    Ben
    Not Beech Creek
    How are you making out?
  11. Sep 29, 2009 at 2:17 PM
    98tacoma27
    Ben
    Not Beech Creek
