Coil packs
Discussion in 'New Members' started by nstorm90, Mar 6, 2023.
  1. Mar 6, 2023 at 5:39 PM
    nstorm90
    nstorm90 [OP] New Member
    Nate
    2006 radiant Red Tacoma sr5
    3” lift kit, Flowmaster FX exhaust. In the process of much needed makeover!
    I recently bought a 2006 sr5 Tacoma 4.0l. Im putting new coil packs in it and plugs. I’m leaning towards the NGK’s because I run NGK spark plugs. What’s everyone’s opinion on this? From all my research Denso or NGK is the way to go!
    trvsl and buckhuntin-tacoma like this.
  2. Mar 6, 2023 at 5:50 PM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    Are the stock coils bad? Toyota's stock coils are very good. They are denso. If they aren't bad don't waste your money.
    Can't go wrong with NGK plugs. Just make sure you get the right ones per the manual.
  3. Mar 6, 2023 at 6:51 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  4. Mar 8, 2023 at 5:35 PM
    nstorm90
    Nate
    My truck has 135,000 miles and it has a rough idle, I just replaced both exhaust manifolds and catalytic converters, also I just put new exhaust on it, the previous owner didn’t take care of it the way it should have been so I’m slowly doing everything.
  5. Mar 8, 2023 at 8:01 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I prefer Denso.
    But 135k isn’t a lot for the coils.
    Have you pulled the coils and inspected the plugs?
    The valve cover gaskets can leak at the plug wells, which lets oil get on to the coil bolts and plugs.
    I start with plugs and a visual inspection first.
