Coil Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bosshoag, Feb 24, 2014.
  1. Feb 24, 2014 at 5:35 AM
    Bosshoag
    Bosshoag [OP] Well-Known Member
    Mr. Doogan
    Pensacola, FL
    '08 4X4 TRD Sport SR5
    I'm here for knowledge folks, please feel free to inform me. -Pioneer Double-Din Receiver -TRD 6-Speed Shift Ball -Low profile black UWS tool box Ordered/En Route: -Wet Okole seat covers -Weather Tech Digital Fit Floor Mats Desire: -Bilstein 5100 Adjustable Shocks -1" Hub Centric Spacers -285/65r18 BFG All Terrain TA K/O's
    My goal is to keep a soft smooth ride similar to stock while lifting my Taco 2". What would be closest to that if I go with bilstein 5100's?
    884's?
    Eibach's?
    Or the preloaded factory springs?
  2. Feb 24, 2014 at 10:02 AM
    Bosshoag
    Mr. Doogan
    Pensacola, FL
    Does anyone have any knowledge or experience with comparing different coil springs?
  3. Feb 24, 2014 at 2:08 PM
    Bosshoag
    Mr. Doogan
    Pensacola, FL
    75 views and no suggestions?! I did just read that billies set at .85" and Eibach springs would be an excellent set up, far superior to preloaded '08 TRD Sport coil springs and billies set to 2.25. Also that you should never set billies to 2.5" with a "lift spring" like Eibach's. Any thoughts? Or further info?
  4. Feb 24, 2014 at 2:14 PM
    OZ-T You chose ... poorly
    884's and billies @ 0
  5. Feb 24, 2014 at 2:20 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    2016 GMC Canyon SLT w/ LineX and....
    This is absolutely true. Never use a LIFT COIL and adjust the billies.
    One or the other.
    Lift coil + billies at ZERO (or stock)
    Stock Coils + billies set to your desired lift
    Why? Too much preload & pressure. A long time ago, I've seen what a LIFT coil and a coil spacer can do - and that's blow out the lower coil seat on the strut.
  6. Feb 24, 2014 at 3:52 PM
    Bosshoag
    Mr. Doogan
    Pensacola, FL
    Hey thanks for the input guys!
    So 884's and billies set at zero will be about 2.5" of lift and ride smooth like stock? I don't want my new truck to ride really rough. That's the goal here.
  7. Feb 24, 2014 at 3:55 PM
    2"
    That's what you said in the OP
    and they aren't going to ride like stock
  8. Feb 24, 2014 at 8:06 PM
    Bosshoag
    Mr. Doogan
    Pensacola, FL
    well whats the stock TRD Baja suspension? isn't it equivalent to a 2" lift? It must be a similarly smooth ride compared to bone stock TRD Sport but taller right?
  9. Feb 25, 2014 at 3:55 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    I went from stock straight to Toytec coilovers preset at 2.5" and rode equal to better than stock. No change in ride when I upgraded tire size to 275/65/18 Dynapro ATMS in a P-metric. Now ride is a tad stiffer but still smooth going to 285/75/16s Rocky mountains due to AT D load tire. Keep in mind the rear lift and shocks will have quite an effect on ride quality too. An AAL will ride stiffer than stock vs. a full soft riding leaf pack. I temporarily ran 1.5" block for the rear with no change in ride quality but it did wear out my factory springs and gave me an occasional axle wrap 'clunk'. My full leaf pack eliminated that.
