Coil replacement question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tiki Tacoma, Sep 15, 2014.
  1. Sep 15, 2014 at 4:53 PM
    Tiki Tacoma
    Tiki Tacoma [OP] Well-Known Member
    CT
    03 dbl cab trd
    I need new shocks and it seems 5100s are they way to
    GO, but i figured i would replace my coils up front while i was in there. I looked into OME coils but i do not want the lift that they will give because i want to leave it stock. Should i use stock coils with 5100s or is it stupid to get 5100s and not lift my truck? At the end of the day i want some quality shocks and coils but i dont want to lift my truck
    2003 4x4 dbl cab
  2. Sep 15, 2014 at 5:08 PM
    scocar
    scocar Patron of the Farts
    If you want to leave it totally stock, you could just get new oem coils and the standard yellow Bilstein HD shocks.
    You won't gain anything from 5100s unless you want to level the stance (which I don't recommend, and it sounds like you are not interested in) and get a shittier ride. Just because they seem to be popular does not mean they are good. I got rid of mine because they becam too harsh, and many people have had them break.
    Don't forget shocks in the rear if they are stil original. You should find a tremendous improvemnt in handling.
  3. Sep 15, 2014 at 5:16 PM
    scocar
    I was counting leaking as breaking...:p
  4. Sep 15, 2014 at 5:49 PM
    Tiki Tacoma
    CT
    03 dbl cab trd
    The omu 880s give a inch or two of lift which i dont want
  5. Sep 15, 2014 at 6:08 PM
    scocar
    Actually Ben, you might have your wires crossed tonight. I am seeing 1.25 to 1.5, and 881s are 1.75 to 2, depending on cab styles and engine, respectively.
  6. Sep 16, 2014 at 8:34 AM
    Tiki Tacoma
    CT
    03 dbl cab trd
    So this hasnt answered my question. Are there are any good coils that wont raise my front end? I have a double cab and i think i saw somewhere that 880s will raise .5 inches in a double cab, will that make that much difference to have my front a half inch higher?
  7. Sep 16, 2014 at 10:14 AM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    Moog coils are pretty good. Cheap too.
  8. Sep 16, 2014 at 4:55 PM
    REEFDUP
    REEFDUP Well-Known Member
    Ron
    Gulf Shores,ALABAMA
    04 TACOMA 4DR 4WD V6 AUTO
    Pro Comp,Rock Stars/ BFG Rugged Trail
    Recently warrantied mine because of leaking oil, they asked for a pic of the shock and i emailed them one.I purchased another shock, sent my leaker back and was refunded for the purchase.
