Coil spacer vs. Bilstein 5100
Discussion in 'Suspension' started by Justinclark19, Oct 4, 2011.
Coil spacers vs. Bilstein 5100
  1. Bilstein 5100
    94.0%
  2. Coil spacers
    6.5%
  1. Oct 4, 2011 at 8:45 PM
    Justinclark19
    Justinclark19 [OP] New Member
    Justin
    Texas
    12' PreRunner
    Bilstein 5100 ride height adjustable front struts, Bilstein 5100 rear struts, Revtek 1 1/4" block kit, Kenwood 7" fold out monitor, Alpine Type R 6.5" components, Alpine Type R 10" dvc sub, Alpine M1000 mono amp, Alpine F300 4-channel amp
    Having a problem with ride quality. Currently have a 3" revtek lift but rides like a tank...debating switching to bilstein 5100 but like the overall look currently and am afraid of dropping height since the 5100's only go up 2.5" ....any solutions?
  2. Oct 4, 2011 at 8:49 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    grab the 5100's set them at .85 and grab some eibach coils- then you'll get 3", and a better ride :thumbsup:
  3. Oct 5, 2011 at 3:13 AM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    Are those first gen eibach numbers or second?
    And get the 5100's
  4. Oct 5, 2011 at 3:25 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I have some unused coil spacers if you want to go that route. I didn't.
  5. Oct 5, 2011 at 3:29 AM
    yotamikez
    Valrico
    Isn't that what revtek is? :confused:
  6. Oct 5, 2011 at 3:35 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I think those are top plate spacers. I have a set of those too that never made it onto either truck.
    Uhhhh, nope, I was wrong, well kinda. Revtek = coil spacers, thin top plate spacers & blocks or AALs for the rear.
    http://www.revtek.com/toyotasusp.asp#426
  7. Oct 5, 2011 at 4:57 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    5100's set at .85 and Eibach coils won't get you to 3", you'll be just shy of 2.5". To get to 3" using Eibach coils you need the 3" kit Toytec sells with a thicker top plate.
    But, x2 on the idea! 5100's and lift coils will greatly improve your ride!
  8. Oct 5, 2011 at 5:11 AM
    yotamikez
    Valrico
    Good info thank you.
  9. Oct 5, 2011 at 8:40 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
    OME
  10. Oct 5, 2011 at 9:18 AM
    Justinclark19
    Justin
    Texas
    12' PreRunner
    All I keep hearing though is with the spacer is your risking ruining cv boot and axles ...any comments?
  11. Oct 5, 2011 at 9:29 AM
    Pugga
    Massachusetts
    F-150 Mod
    That spacer does not run any more risk of ruining CV boots and joints than a 3" suspension lift does. Spacers have their own set of risks which include binding of the coil or potentially breaking the shock itself (I'm not sure what type of spacer you have).
    Check out the site below, it was put together by Camburg to show the downside of spacer lifts. The cases they reference are obviously the extreme case as many people run spacer lifts without any problems.
    http://www.camburg.com/toyota/00-06-tundra/read-before-buy-spacer-lift/
  12. Oct 5, 2011 at 9:40 AM
    Justinclark19
    Justin
    Texas
    12' PreRunner
    Revtek Toyota Tacoma 4WD & PreRunner 2005-2011 part number 426 3" coil spacer front, 1 1/4" block rear lift system....
  13. Oct 5, 2011 at 9:44 AM
    Pugga
    Massachusetts
    F-150 Mod
    Check out my post above (I edited it and added a link about spacer lifts). You're much better off using lift coils rather than a spacer lift. As far as CV joints and boots, it doesn't matter if you use a spacer or suspension lift, both have the same risk of prematurely wearing the CV boots and joints if they're at too extreme of an angle. A 3" spacer lift and a 3" suspension lift would carry the same risk since the CV's would be operating at the same angle in both set-ups.
    2010blackprerunner likes this.
  14. Oct 28, 2011 at 5:15 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Spacers = Crap
    Spacers + Blocks = Total Shit
    Poll is currently at 19-0 for 5100's...that should tell you something.
    Fink
  15. Oct 28, 2011 at 9:56 PM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    x2 on both, which is either x3 or x4, but you get the idea...
  16. Oct 28, 2011 at 9:57 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    man i've got 5100's and eibach's and i love the ride quality. i am planning on getting new UCA's though cause i don't wanna wear anything out too fast
  17. Nov 29, 2011 at 1:02 PM
    Fink
    Orlando, FL
    34-0 now...
    Fink
  18. Dec 17, 2011 at 4:59 AM
    SMITTY1
    SMITTY1 Active Member
    Jonathon
    BAMA
    2010 Tacoma SR5 TRD 4WD
    I have looked at the 5100's but not really sure which kit I want to go with. I plan on getting new wheels and tires as well. I know this post probably dont belong here but where can I peek at some of your rides to help me make up my mind on ride height, kit..etc
    Thanks,
  19. Dec 18, 2011 at 12:22 PM
    FL TRD
    FL TRD Well-Known Member
    Florida
    05 Prerunner SR5 TRD
    I voted for the spacers because depending on what your using the truck for they can be good. I know alot of people that use them but there trucks and suvs are not hardcore off roaders if you want it for the looks there fine but not recommended for serious off road use for sure. The only way you can break a shock like some of the peoples pics show is by jumping your truck. I use them and have had no problems and alot of times they ride a good as stock. just my opinion though i dont do alot of off roadind with my truck I have atvs and a built jeep for that but it looks nice towing everything to the mud pits lol.
  20. Jan 9, 2012 at 6:56 AM
    Pugga
    Massachusetts
    F-150 Mod
    If you haul fairly heavily I wouldn't use spacers either. All it takes it to bottom out once and you're completely screwed unless you have taller bump stops. The aftermarket coils are generally stiffer and the 5100's do a better job dampening the ride. In my opinion, the stiffer coils are better for a taller truck. Truck roll in a lifted truck = scary. Spacers do work for looks but it's money wasted in my opinion. I'd rather spend a little more, get the look I want and also ride improvement. For the rear, blocks promote axle wrap and can wear out a leaf pack quicker.
