Coil spacers with longer coil spring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by berryd, Jul 26, 2015.
  1. Jul 26, 2015 at 9:31 AM
    berryd
    berryd [OP] New Member
    Dillon
    2006 silver Tacoma prerunner
    I need more lift and I was wondering if I had a 3in coil spring with also a leveling kit coil spacer if they would work together?
  2. Jul 26, 2015 at 10:41 AM
    MotoMoose68
    MotoMoose68 Well-Known Member
    Ed
    Southwestern Colorado
    2014 Tacoma TRD Sport
    Strut Spacer and block lift, w/33" tires on custom wheels.
    I may be wrong, but I think combining them both would be too much lift and you would need to lower/lengthen your control arms, the way the bigger lift kits do. I believe it would be next to impossible to get enough adjustment to correct the negative camber you would get.
  3. Jul 26, 2015 at 11:20 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Why do you need more lift? Have you added a heavy bumper and winch that compressed your 3" coils? Going beyond 3" up front is going to require more than just adding a spacer for correct geometry.
