Coil Spec question for 3.4
Discussion in 'Technical Chat' started by JJ04TACO, Jan 28, 2019.
  1. Jan 28, 2019 at 12:01 PM
    JJ04TACO
    JJ04TACO [OP] Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    So I chased down a P0303 and it was a plug (replaced plugs). Subsequently I tested the wires (fine) and the coils (not fine but how bad?)
    The primary (+- terminals) were at 1.2, 1.3, 1.3 Ohms (Spec is 0.67-1.05 Ohms cold) No bueno. Barely out of spec...
    The secondary (plug wire connection to plug connection) were fine at 12.4, 12.5, 12.73 Ohms. (Spec is 9.3-16.0 Ohms)
    Other than efficiency, any known issues running these coils out of spec even just barely?
