coil spring advice
Discussion in 'Suspension' started by jr114, Jan 11, 2010.
  1. Jan 11, 2010 at 8:57 AM
    jr114
    jr114 [OP] Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    ok guys. so my spindles are ordered, and i have the billy 5100's sitting in the garage. now i need to order coil springs. i was originally going to order the eibachs but now im having doubts. im not sure if ill gain too much lift from them. im trying to get around 5" up front. any ideas on springs i could use or should i just go with the eibachs?
  2. Jan 11, 2010 at 11:20 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I can set you up with some OME coils. You can combine those with a low setting on your 5100s or just use the 5100s with your factory springs to lift 2.5"
  3. Jan 11, 2010 at 11:29 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    ^wrong. He said he has spindles, those give 3.5" for tc or 4" for camburg. Therfore so him to have no travel he would be pushing what like 7-8" of lift for that to happen.
    To the op with my spindles I am running eibachs with the collars and 5100. If you can't find that or don't want adjustable coilovers like that just set the 5100's at the .85" setting and you'll be golden. Even if you wanted to add another 1"or so get the top plate spacer kit from toytec that goes on top of your coilover assembly. With that you will be sitting around 5.5-6".
    Edit: just a fyi the springs that give 1.5" eibach sells is different than the ones in the setup with the collars. I think toytec sells the spring with collar without the shock, then just use your current top plate
  4. Jan 11, 2010 at 3:12 PM
    jr114
    Jon
    SoCal
    Truck
  5. Jan 11, 2010 at 4:27 PM
    08pretaco
    az
    Just the springs off their coilovers. The springs in their coilover setup are flat at the bottom and don't taperlike the lift ones they sell by themselves. So I have the flat coils which I use with the collars, which gives me adjustability. So the setup I got now I can go from 4" with zero lift or 7" up front with the coilovers cranked to 3". The regular eibach springs give 1.5" from the get go.
  6. Jan 11, 2010 at 4:29 PM
    08pretaco
    az
    You could also just use your stock springs with the 5100's and preload them to the .85" setting and sit close to 5". I think it would be less than that so you could get a 1/4" top plate spacer and be sitting around 5.25" or pretty close
  7. Jan 11, 2010 at 5:06 PM
    jr114
    Jon
    SoCal
    Truck
    Problem is that I don't have the stock coils anymore. Toytec says the ome 881s are pretty much the same as stock. So I may go that rte with the coils and a 1/4" spacer on the drivers side and the shocks set at 0.85. Anyone have any advice on these coils?
  8. Jan 11, 2010 at 5:39 PM
    08pretaco
    az
    I'm pretty sure I got the stock spring I could sell you if you want
