Coil Spring Compressor. Safest/most affordable/functional
Discussion in 'Suspension' started by 6spdtaco, Feb 5, 2012.
  1. Apr 10, 2012 at 5:32 AM
    Swampmonkey
    Swampmonkey Well-Known Member
    Wes
    Fairhope, AL
    2011 Prerunner TRD DC
    UWS black low profile toolbox, TRD intake, TRD exhaust, TC uca's, Rear 2" toytec aal, OME Front and Rear shocks, OME 885s, NFABs
  2. Apr 10, 2012 at 6:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Take the coil assembly to a garage that has a wall mounted compressor and pay them $20 to have it done. Let them deal with it....
  3. Apr 10, 2012 at 6:25 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  4. Apr 10, 2012 at 7:21 AM
    dmb
    dmb Well-Known Member
    Boise, ID
    Used this method to install OME 885x coils on my 5100s this weekend. Worked like a charm.
  5. Apr 10, 2012 at 7:32 AM
    Fuze911
    Fuze911 Well-Known Member
    Maryland
    05 Taco TRD
    Used that video method to install my 5100s at 2.5. Worked great.
  6. Apr 10, 2012 at 7:56 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    The video method is the only way to go. so much easier than using a spring compressor!
  7. Apr 13, 2012 at 1:38 PM
    socal147
    socal147 Active Member
    patrick
    Apple Valley Kalifornia
    12 PreRunner SR5
    Just Bought It = NONE
    After reviewing this video and looking under my 2012 Prerunner, I need to say this is the way to go. I think being a two wheel drive will make the job even easier. Now I need to decide on where to set my Billy's.
    Outstanding video. Took the guesswork out of my untried thought pattern.
    UPDATE: Installed rear 5100's. The difference from front to rear is now @1.75" ..... Hmmm
    Guess I will be setting my front 5100's to 1.75. I will update with pics before and after.
    Update #2
    Completed in about 4 hours. Mostly due to my learning curve. I did have to remove the brake line and AntiSkid wiring brackets to prevent damage. I also disconnected the UCA Ball Joint. Good lesson and Thanks again for the video.
    Update #3
    Got my Ride Rites installed. Alignment completed. Ride is better.
    I am very happy with the appearance.
  8. Apr 19, 2012 at 12:30 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DCSB SR5 V6 AT TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    I'm doing the video method this weekend. Thanks TW and members.
    BTW, what are the torque specs for these bolts? Is it hard to break the lower control arm bolts loose?
  9. Apr 19, 2012 at 12:44 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    not sure on torque numbers but the bolts are not bad with the right tools. I have a big torque wrench that I use and it gives me plenty of leverage to get stubborn bolts.
    you can get one from harbor freight for less than 20 bucks of you dont have one.
  10. Apr 19, 2012 at 1:18 PM
    dmb
    Boise, ID
    I've got the torque specs written down at home. The bolts holding the LCA to the frame weren't bad. The two underneath the lower ball joint are on there pretty good. Spray some PB on em and that helped out. Will you have somebody helping you? I did it myself...would of been easier if I had two jacks, but I gottr' done.
  11. Apr 19, 2012 at 3:54 PM
    BTO
    California
    By myself but I have two floor jacks, a bottle jack, four jack stands and a bunch of tools with air tools too . With all this info from everybody I feel very confident it will go smooth.
  12. Apr 19, 2012 at 4:06 PM
    dmb
    Boise, ID
    You'll def be good to go!
  13. Apr 20, 2012 at 11:25 PM
    Spacewrangler
    Spacewrangler New Member
    Idaho
    09 Off Road
    2" Leveling Kit
    Can I use this method for putting on 2" in-coil spacers too? Hoping to tackle it this weekend so I can get new wheels and 265/75R16 DuraTracs.
  14. Apr 21, 2012 at 4:41 PM
    BTO
    California
    Just finished mine plus a tire rotation. 4 hours and a bad back later...
    Be sure to mark the LCA adjustments with white marker. I made the mistake of using black on the first one and had a hell of a time getting it correct. Who knows if it really is?
  15. Apr 21, 2012 at 4:56 PM
    #35
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I might have to invest in the second one on the list, just to add to my collection.
    #35
  16. Feb 17, 2013 at 4:57 PM
    #36
    phatso
    phatso Well-Known Member
    Eastern Washington
    2017 Cement Pro
    Thank you for this video. What a life saver! Did it today and no problems whatsoever.
  17. Feb 25, 2013 at 1:23 AM
    #37
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Sub'd. Puttin 5100's on this week!
  18. Feb 25, 2013 at 1:31 AM
    #38
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
  19. Feb 25, 2013 at 2:11 AM
    #39
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Dome this as well very easy
  20. Feb 25, 2013 at 9:39 AM
    #40
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
