Coil Spring for Pro Suspension
Discussion in 'Downsouth Motorsports' started by 58LesPaul, Jan 4, 2018.
  1. Jan 4, 2018 at 3:23 PM
    58LesPaul
    58LesPaul [OP] Well-Known Member
    Jeff
    Kentucky
    2013 Tacoma TRD Sport 4x4 DCSB
    2" Lift
    I bought a suspension that I was told was off of a Tacoma Pro. After installation I found out from the guys on TacomaWorld that I actually have a 4Runner Pro suspension. The only difference is the front coil spring. I was expecting to get 2" of lift with the Pro suspension but I am now at 20.5" center of wheel to bottom of fender while I added an AAL to the rear and I have 23.75". I would like a coil spring to give me about 22.25"-22.5" on the front. Do you have a coil spring for the Pro suspension that will give me 1.75-2" of lift?
    2013 Tacoma 4x4 DCSB Sport with Pro shocks.
  2. Jan 4, 2018 at 3:30 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    OME 885s or 887s should do the trick
  3. Jan 4, 2018 at 3:32 PM
    58LesPaul
    Jeff
    Kentucky
    2" Lift
    Will those work with the Pro suspension with the bigger diameter shocks?
  4. Jan 4, 2018 at 3:34 PM
    eon_blue
    Azusa, CA
    If not then some 650 or 700lb King shocks should do the trick, are the 2.5 shocks? King, Icon, SAW...pretty much anyone that makes 2.5 performance coilovers should be able to sell you the coils separately.
    edit: not sure about the length of those though, seeing as how the Pro shocks aren't adjustable right?
  5. Jan 4, 2018 at 3:36 PM
    58LesPaul
    Jeff
    Kentucky
    2" Lift
    Correct, well one adjustment for lean.
  6. Jan 4, 2018 at 3:43 PM
    eon_blue
    Azusa, CA
    I'd give DSM a call (or try Marie @HeadStrong Off-Road, they're quick to respond) and they should be able to source the correct coils for the height you want. I'm sure any of the big companies makes them
    itaro likes this.
  7. Jan 4, 2018 at 7:34 PM
    Rusty15Tacoma
    Rusty15Tacoma Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    If the pro coils are flat bottom, OME’s will not work. You’ll need Eibach or something similar (King, Fox, Icon-assuming they are 2.5” collars)
