Coil spring rate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mgaspard, Feb 4, 2019.
  1. Feb 4, 2019 at 5:03 AM
    mgaspard
    mgaspard [OP] Well-Known Member
    Mark
    Louisiana
    2018 SR5 4x2 Silver Sky DCLB
    N-Fab Podium steps, Katzkin Leather, painted bumper, Method MR315 Machined 17 x 8.5, Toyo Open Country A/T III, Fox 2.0 front and rear
    Does anyone know what the front coil spring rate is on a 2018 DCLB Sr5?
  2. Feb 4, 2019 at 6:39 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I thought stock was around 600 or 650
  3. Feb 24, 2019 at 11:05 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    I’d be interested to know the front stock coil spring rates on Sr5, Sport, OR and Pro.
    Anyone have info? I’ve searched and haven’t really found exact numbers.
    Kodiak420 likes this.
  4. Feb 24, 2019 at 11:09 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    The Fox Pro springs are 650 lbs... I asked a Fox rep.
    Spring specs:
    12.3X3X650
  5. Feb 24, 2019 at 11:09 AM
    Grossomotto
    2017 4WDV6LB6MT
    Thanks, so the others must be less
  6. Feb 24, 2019 at 11:15 AM
    JoeCOVA
    Joe
    Colorado Springs
    I think stock is 600
  7. Feb 24, 2019 at 11:17 AM
    Grossomotto
    2017 4WDV6LB6MT
    That would seem about right and if so I may just stay with stock coils instead of the 590lb OME.
    71tattooguy likes this.
  8. Feb 24, 2019 at 12:29 PM
    trdt44
    trdt44 Well-Known Member
    Trent
    Utah
    2017 Tacoma TRD OR
    gudujarlson likes this.
  9. Feb 24, 2019 at 12:36 PM
    JoeCOVA
    Joe
    Colorado Springs
    Interesting, looks like the 2nd gen coil rate was 500 lbs?? Most people were upgrading their coils to 700lbs on the 3rd gen to compensate for aftermarket bumpers and winches, sounds like then people would need to go to a 750-800 lb coil
  10. Feb 24, 2019 at 1:05 PM
    Grossomotto
    2017 4WDV6LB6MT
    Ok, is that for all models? I thought Sport and OR and Pro were all different.
    I’m considering OME springs, but if the rate isn’t more than stock, then I’ll just stay with stock.
  11. Feb 24, 2019 at 1:07 PM
    JoeCOVA
    Joe
    Colorado Springs
    Well something is odd, Pro coils are 650 but stocks are 717??
    SR-71A likes this.
  12. Feb 24, 2019 at 1:10 PM
    Grossomotto
    2017 4WDV6LB6MT
    Doesn’t seem right. That’s why I’m trying to figure out the rates of the different stock models. I’m thinking Sport and OR are about 600
    Pearson and JoeCOVA[QUOTED] like this.
  13. Feb 24, 2019 at 1:16 PM
    JoeCOVA
    Joe
    Colorado Springs
    The coils that Toyotec offers in their coilovers and lifts is 650 as well according to their website. I dont know if 717 is a good figure.
    Me personally, I went 700 because the consensus was 600 and I have a ton of weight up front.
    Grossomotto[QUOTED] likes this.
  14. Feb 24, 2019 at 3:29 PM
    trdt44
    Trent
    Utah
    2017 Tacoma TRD OR
    I agree it does not make sense but I have not been able to find anything saying different. I assumed that is why Bilstein has different shocks for 3rd versus 2nd gen. The explanation I read, I think it was in the Toytec thread, is the higher rate spring can actually feel smoother on the small bumps if the correct shock valving is used.
    I do know the 3rd gens sit higher up front. Also with the Bilstein 8112 shocks the same shock settings produce 0.6" less lift height on a 3rd gen. I have been having a discussion with a Bilstein tech about my shocks, I will see if he can tell me.
    Eta: I plan on to also install 700lb springs also once my bumper gets here.
  15. Aug 6, 2019 at 9:03 AM
    SpeedwayTaco160
    SpeedwayTaco160 Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    bump, so would you guys recommend a 2nd gen guy purchasing a 3rd gen OR or Sport shock and coil for say a ARB bumper?
  16. Feb 12, 2021 at 10:22 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Has anyone confirmed the 3rd gen stock spring rate yet?
    (im trying to choose new springs)
  17. Feb 12, 2021 at 10:30 AM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    I've read stock 700ish before on here. Now i regret getting 600lb on my 6112(not installed yet). But so many were saying the ride would be harsh with 650 and no added weight.
  18. Feb 12, 2021 at 10:36 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Stock coils are in the neighborhood of 550lbs ±15.
    OME 887's are 590
    Most aftermarket "big bodies" start at 12" 600.
    The Tacoma should never need more than a 700 fully kitted out.
    If you don't have steel armor and or a winch up front 600 should be enough, if you have steel armor but no winch 650.
  19. Feb 12, 2021 at 10:40 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    ^^^ This is 2nd gen info. The 3G is much heavier with heavier coils.
    I read here somewhere 700lbs stock coil for 3G taco.
    71tattooguy, Dirk Diggler and SR-71A like this.
  20. Feb 12, 2021 at 11:40 AM
    Key-Rei
    Key
    Florida
    That's insane, it would ride like a dump truck. :crazy:
    OhNoItsMe, Bee Finn and hiPSI like this.
