Coil spring
Discussion in '1st Gen. Tacomas (1995-2004)' started by Matty87, Jan 28, 2024.
  1. Jan 28, 2024 at 7:46 PM
    Matty87
    Matty87 [OP] New Member
    98 Toyota Tacoma sr5
    Lookin for part number to order new spring coils front. Please just the coils I need cuz it’s sagging it’s all stock and plus I have the new 2.5 coil boot for them just need to order new coils
  2. Jan 28, 2024 at 11:01 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is your truck all stock, no lift? Are the springs you have now just wearing out, sagging?
    Are you looking to replace an original spring with a Toyota oem spring?
  3. Jan 29, 2024 at 2:37 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
