Coil Springs with Shocks vs Coilovers for a Parallel rear 4 link setup?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pinoiako916, Feb 11, 2015.
  1. Feb 12, 2015 at 5:16 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    When you are building a rig like that basically you need a good motor and trans. Everything else is going to be custom made and fabbed.
  2. Feb 12, 2015 at 6:08 PM
    Pinoiako916
    Pinoiako916 [OP] Well-Known Member
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    Most likely then the custom parallel rear 4 link coil spring set up will run $10,000 alone.
  3. Feb 14, 2015 at 10:43 PM
    bzzr2
    bzzr2 Well-Known Member
    i guess it's ok to dream!
  4. Feb 16, 2015 at 7:20 PM
    Pinoiako916
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    Coil overs are harder to package than coil springs, but they have a lot more tunability as compared to coil springs.
  5. Feb 16, 2015 at 7:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    Why not start with an older truck, hit in the rear? Preferably with a popped motor.
    Put an LSx and matching trans in place, T56 w/GearVendors OD, then build the appropriate rear suspension. Maybe graft in a Caddy IRS, Getrag diff, discs, etc. Or a Ford 8.8 if you prefer solid axle.
  6. Feb 16, 2015 at 7:46 PM
    Pinoiako916
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    You bring up a good point about using an older model Tacoma instead to Parallel 4-Link the rear. The reason why I am going for a coil spring w/ shock setup together with limiting straps is because it will be easier to flatbed it instead of a 4 link coil over. The only limitation of a coil over is that they will go through the bed space.
  7. Feb 17, 2015 at 9:11 AM
    Sccafire
    Sccafire KMG 365
    Cleburne, Texas
    2023 Jeep Gladiator Rubicon
    If I am not mistaken, the picture of the green truck you posted has a triangulated 4-link. Just remember the parallel 4-link will require a rear track bar to center the axle. A triangulated 4-link will not.
  8. Feb 17, 2015 at 9:21 AM
    Pinoiako916
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    @Sccafire - how do you prevent coil springs from popping out when four wheeling? Are spring retainers, and limiting straps good in accomplishing this? I see that you are based in Lincoln,ca by Roseville. I messaged you.
