Coil Springs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jsnemec, Jan 4, 2025.
  1. Jan 4, 2025 at 7:44 PM
    Jsnemec
    Jsnemec [OP] Active Member
    Josh
    18 Tacoma TRD OR
    Do the coil over springs vary between different trims and years? SR vs. off-road, etc. I know the shocks vary based on trim but wasn’t sure about the springs. Thanks!
  2. Jan 4, 2025 at 7:59 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes but it has more to do with weight and trim level/cab configuration. It's really hard to get replacement correct left and right springs for some trim levels. There's also limited information on them.
    2nd gens are basically limited to aftermarket coils now, its really hard to get the correct spring anymore.
  3. Jan 4, 2025 at 8:05 PM
    Jsnemec
    Josh
    18 Tacoma TRD OR
    @Bishop84 thanks for the input. I have an 18’ off-road that I am going to upgrade to 5100s on. Would like to have a shop assemble before I do the install to help streamline things. Stock springs can usually be found for cheap, but don’t want to get oem springs from an SR or whatever if it’s not a good idea for my setup.
