Coilover Adjustment Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Voos, Jul 23, 2009.
  1. Jul 23, 2009 at 9:58 PM
    Voos
    Voos [OP] Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    Just installed new Icons.. My question is... If the coilover is supposed to be adjusted with the wheels of the ground, how does one obtain an accurate measurement??
  2. Jul 23, 2009 at 10:10 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    lift the wheels off the ground to get as much pressure off the shocks so you can turn the ring easier. Just count how many times you go around then do that to the other side, or you can measure from the ground to the bottom of the fender so you can take care of the tacoma lean.
  3. Jul 23, 2009 at 10:11 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    It is sort of trail and error. After you adjust them you need to drive it around to make the suspension settle, and then take your measurements.
    (5/8" of thread exposure, will yield 1" of lift.) it's approximately a 2 to 1 ratio.
    Adjust accordingly as needed.
  4. Jul 23, 2009 at 10:42 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    and everytime you change the setting you will have to get an alignment, so make sure they are set where you want them.
  5. Jul 23, 2009 at 11:15 PM
    icon2
    icon2 ICON VEHICLE DYNAMICS Vendor
    Corona
    Just remember to release the set screw that is located in the adjuster ring. 4 complete revolutions of the adjuster ring equals a 1/2" of lift height. I would recommend jacking up the side that you are working on and remove the wheel. Shoot some penetrating oil on the threads of the shock can just to make sure that the ring moves freely. make a chalk mark on the ring so you can easily follow the amount of revolutions. Release the set screw and begin your adjustment with a spanner wrench. If you do not have a spanner wrench you can use anything that fits snugly in the holes of the adjuster ring (drill bit, Phillips screw driver, metal dowel, etc.). If you have any questions please do hesitate to give us a call. Thanks and enjoy the coil-overs.
  6. Jul 24, 2009 at 1:14 AM
    toku58
    HAWAII
    4x4 Beast!
    Good to know! Nice to see you guys here!
    You know my C/O's; I have never used the set screw. (Don't want to damage the threads.)
    But when I jack up the truck, I use some of those cheap coil compressors from Autozone to compress the coils, and I'm able to spin the collars by hand really easily.
    I have never had any issue with the collar spinning on it's own, without the set screw.
    Have you guys had problems with the collar spinning, if the set screw isn't dogged down?
  7. Jul 24, 2009 at 8:16 AM
    icon2
    Corona
    No not really. With the pre-load that is on them you should not have an issue. The set screw is there as a fail safe measure.
  8. Jul 24, 2009 at 9:06 AM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Sorry to hi-jack but I had a question for the icon rep. I have 3 year DR coilovers and was wondering if I should send them in to get rebuilt. I didn't do any major off-roading with them and they appear to run just fine. What do you think?
  9. Jul 24, 2009 at 9:56 AM
    icon2
    Corona
    As long as they are functioning properly and show no signs of leaking i would keep driving on them. Thanks
  10. Jul 24, 2009 at 10:17 AM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    How many miles have you put on the coilovers? Any rust yet from the Houston humidity?
  11. Jul 24, 2009 at 11:51 AM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    Actually, they are about 2.5 years old. Probably have about 25,000 miles on them and there is no sign of rust on them.
  12. Jul 24, 2009 at 1:59 PM
    bermise
    Houston
    08 TRD off road
    Good to know. I have only had my Icon coilovers for about a year but have 20,000 miles on them already. So far so good.
  13. Jul 27, 2009 at 4:06 PM
    bermise
    Houston
    08 TRD off road
    So are you supposed to adjust these with the wheels attached and on the ground? Or jacked up?
  14. Jul 27, 2009 at 4:15 PM
    bermise
    Houston
    08 TRD off road
    Nevermind Mike, good talking to you on the phone. Thanks for the help.
  15. Jul 27, 2009 at 4:18 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I would definately jack the truck up makes it alot easier.
  16. Jul 27, 2009 at 4:20 PM
    icon2
    Corona
    Yes you want to adjust them with the wheel off the ground.
  17. Jul 27, 2009 at 4:24 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    i did two complete revolutions on the drivers side c/o to level out the taco lean
  18. Jul 27, 2009 at 4:44 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Just an FYI, I ran a set for 130,000 miles in 3 1/2 years here in NH with no issues except they developed a squeak in the lower bushings. Replaced the bushings for ten bucks and they were good as new. Great CO's!
  19. Jul 27, 2009 at 4:49 PM
    bermise
    Houston
    08 TRD off road
    Wow, that is reassuring to know. I think Icon should give bb609 some kind of a discount for the good marketing rep.
  20. Jul 27, 2009 at 4:51 PM
    toku58
    HAWAII
    4x4 Beast!
    If you guys are worried about corrosion? Try a product called "T9" spray the C/Os with it. It is the best thing out there at this point. It dries to a wax like finish and doesn't collect dust. It will wipe off easily with a rag.
    Keeps them in perfect condition!
