Coilover and UCA Install Question
Discussion in 'Suspension' started by Canadianboy, Aug 21, 2009.
  1. Sep 7, 2009 at 9:48 AM
    #41
    Canadianboy
    Canadianboy [OP] Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    Right on, thanx for all the help guys. I just need to adjust my coilovers a bit and get my new tires and wheels mounted then I'm all set! I took it for a quick spin last night and everything felt fine. No vibs or weird noises. The truck feels much more firm and solid. I don't know if its related to my alignment, but the few times I hit a pot hole, the steering wheel spun to the left really hard. Hopefully an alignment gets that sorted. Pics to come soon.
  2. Sep 7, 2009 at 4:53 PM
    #42
    sonjay
    sonjay Well-Known Member
    I hooked that bracket for the park brake up and have had no troubles? I didn't notice if mine was tight or not. I've had my dakars flexed out and no issues.
  3. Sep 7, 2009 at 6:45 PM
    #43
    Canadianboy
    James
    Vancouver, BC
    Nice, I decided to leave the bracket on for now also. Did you have any vibration issues in the rear? After driving around for a bit today, I can notice a very subtle vibration when slowly accelerating. I only lifted the rear 1.5", so I thought vibs wouldn't be a problem. I had the rear axle down pretty far, maybe its related to this? I also noticed some squeaking coming from the rear leafs. I'm going to re-torque the u-bolts and put some spray lub between the leafs, hopefully that sorts it out. Now to figure out this little vibration.:confused:
  4. Sep 8, 2009 at 4:22 AM
    #44
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    PM Chris4x4 on that vibration. You may need some shims on the axle to correct the pinion angle. He warned me about that when I did mine, but I didn't need them.
  5. Sep 8, 2009 at 6:13 AM
    #45
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct. Sounds like shims are the answer. :)
  6. Sep 8, 2009 at 4:36 PM
    #46
    sonjay
    I had a 1 piece drive shaft made up and my vibes went away!
