Coilover Clicking/binding
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tommytomtoes, Mar 5, 2017.
  1. Mar 5, 2017 at 10:21 PM
    Tommytomtoes
    Tommytomtoes [OP] Active Member
    Thomas
    2016 trd sport 4x4 Tacoma
    I drive a 2016 trd sport 4x4. I have a little over 8k miles on it. I just recently had the icon stage 1 kit installed which comes with new coilovers and shocks. The first day after the install I noticed a binding/clicking coming from the front driver side when almost stopped and when I first start moving again. It doesn't start right away when I first start driving it usually takes a couple minutes. I've looked at the cv angles and they seem fine and I've also checked the tightness of the hardware. Has anyone had a similar experience? I have a hard time believing it's something giving out on such a new truck and I hope it's not the actual coilover. Please help!
  2. Mar 6, 2017 at 7:46 AM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    Did you install the sway bar relocate spacer as well? Depending on where you ordered your kit and who did the install, it could have been left out.
    Check your spring/sway bar for contact.
    OA
  3. Mar 7, 2017 at 3:39 PM
    Tommytomtoes
    Thomas
    Yeah it doesn't look like anything is contacting at all
  4. Mar 7, 2017 at 3:59 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    did you loosen the lower control arm bolts? They will click and pop if a little loose. Torque is about 100#. BUT also remember that you have removed the rubber cushions that separate the suspension bits from the metal body. You will get a little bit more "racing noises".
  5. Mar 7, 2017 at 4:01 PM
    medic2230
    Murph
    Bama! Roll Tide
    Don't you have to run aftermarket UCA's with Icon's?
  6. Mar 8, 2017 at 12:59 AM
    Tommytomtoes
    Thomas
    That could be it I'll look at that. It's actually quieted some. Might be because they're new?
  7. Mar 8, 2017 at 1:01 AM
    Tommytomtoes
    Thomas
    I don't think you have to. The stage one kits come with the coilovers and rear shocks and the stage two comes with that plus the upper control arms.
  8. Mar 8, 2017 at 1:21 AM
    16TRDoff_road
    16TRDoff_road Active Member
    Brett
    Cornwall, NY
    2016 Tacoma TRD off road quicksand
    Full OME Kit (888 coils, Dakars), 285/70r17, Pro Comp Rockwell wheels
    I'm having a similar issue with my OME lift. I have aftermarket UCA's installed. It's been about a month and a half since I had it installed. I get a clicking sound only when the truck is in drive and at a complete stop. It sounds worse inside the cabin than outside. I have yet to pin point the noise.
  9. Mar 8, 2017 at 10:45 AM
    Tommytomtoes
    Thomas
    I can't hear mine inside at all. It's dualing out now but can still hear it if I have the window down and almost at a stop and when I first accelerate. I feel like it's something super simple that's right in front of my nose.
  10. Mar 8, 2017 at 10:58 AM
    16TRDoff_road
    Brett
    Cornwall, NY
    Yeah, I wouldn't be crazy worried about it. As long as everything is tight and aligned good, think you'll be fine.
