Coilover Confusion
Discussion in 'Suspension' started by DAN LUSHER, Oct 12, 2008.
  1. Oct 12, 2008 at 4:46 PM
    DAN LUSHER
    DAN LUSHER [OP] HI-TECH LIFTS
    ELYRIA, OHIO
    TACOMA
    3.5 INCH LIFT , MORE TO COME.
    My shop over the last 8 years has specialized in mostly domestic truck suspension upgrades with a little dabbling into jeeps, we have vast knowledge in all aspects of lifting vehicles. I decided to purchase a 2009 Tacoma crew cab 4 by trd and lift her up, normally I go A MINIMUM OF 6 INCHES but opted not to butcher the frame until out of factory warranty. Money was not an issue so I ordered up NEW ICONS what nice units until it all went wrong. The installation was a cake walk I wanted 3.25 up front and aals and a 1 inch block in rear, we tried adjusting the collars with the supplied spanner up to max recommended 2 inch threaded space with allen set screws removed truck elevated on a lift, it took two people and a bar to move these collars marring them severly, these are ivd coated icons and not my first experience with coilovers, I have never had nor seen this type of difficulty. My only answer to this the ivd coating on the threads any input would be appreciated
  2. Oct 12, 2008 at 4:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to Tacoma WOrld!
    I have heard about the Icon coilovers being hard to adjust, and haveing a poor quality thread. Give them a call and see if they will help ya out. :)
  3. Oct 12, 2008 at 11:29 PM
    20taco07
    20taco07 Well-Known Member
    sacramento
    2007 toyota tacoma sr5 trd sport 4x4
    i have the same coil overs and it is a peice of cake to install and adjust the height. all you have to do is jack up the front end of the truck so the wheels are in the air to releive the extra pressure on the coil overs, loosen up the allen screw and use the wrench provided to lift it up. very easy to do.
  4. Oct 13, 2008 at 4:17 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    I really hope no one would try adjusting Coil over with load on them....
    Becuase it sounds like you tried it that way...
    Most Coliovers need to have all the load taken off...
  5. Oct 13, 2008 at 4:19 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i think he had the load off of them
  6. Oct 13, 2008 at 4:31 PM
    DAN LUSHER
    ELYRIA, OHIO
    TACOMA
    Truck was elevated on a lift. I have been in business 10 yrs now and a master toyota, gm and ase meachanic for 23 yrs, if you have seen as much junk parts as i have you would have givin up. I loose 2k a month to bad parts or warranty of parts installed and failed. Whose to blame china and and poor quality control. Sometimes the best isnt all that it seems. Enough said thanks for your input.
  7. Oct 15, 2008 at 9:53 AM
    sooner02r1
    sooner02r1 Well-Known Member
    I doubt it had anything to do with the threads binding like that, but 3.25" of lift is too much on those coilovers. The stock arms on the Taco do not work well at that height. You should look into Allied lift spindles and some aftermarket uniball upper control arms like Camburg or Total Chaos if you want that much lift. I would call up Icon to deal with the junk threads. Also I would run a whole new leaf pack in the rear instead of AAL if you really wanna do it right.
  8. Oct 15, 2008 at 3:23 PM
    DAN LUSHER
    ELYRIA, OHIO
    TACOMA
    Truck is equipped with light racing control arms , purely the case of over toleranced components , i know its hard to believe that something in this day and age could be falible.
  9. Mar 13, 2010 at 5:58 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    Thanks, that's good to hear. I am going to be installing my rear lift soon and will be cranking up my front c/o another inch. I was wondering if I was going to need a spring compressor or not. Doesn't sound like it:)
  10. Mar 13, 2010 at 6:29 PM
    BUZZ5
    BUZZ5 Well-Known Member
    S.Carolina
    07 Prerunner DC TRD Sport
    Many
    He said it was a 4x; the spindles won't work.
  11. Mar 13, 2010 at 8:35 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Make sure the allen bolt is loose enough and spray some lubricant on it, otherwise completely remove all the pressure and unbolt the shock and drop the lower out completely than crank it down with the spanner.
  12. Mar 13, 2010 at 8:56 PM
    JimBeam
    JB
    2015 Tundra
    wow old ass thread
