Coilover conversion for 5100?
Discussion in 'Suspension' started by VirginTaco, Mar 18, 2022.
  1. Mar 19, 2022 at 12:21 PM
    VirginTaco
    VirginTaco [OP] Member
    2020 trd sport 4x4
    what are you talking about by larger diameter? A 2” shock requires a 2.5” I.D. Coil spring. I want a 16” long coil. The 2888 is the only coil I found at that length and are notorious for sagging. And $60 more than the kings.
  2. Mar 19, 2022 at 12:24 PM
    FloTaco
    FloTaco Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    OP, definitely a viable idea but that specific sleeve you posted runs the risk of spinning on the shock body when you go to adjust the spring, where as Toytec’s design has a milled lower nut that allows you to immobilize the sleeve while adjusting the spring perch collar.
  3. Mar 19, 2022 at 12:44 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    We have a disconnect. Your first post implied to me that you were trying to combine a shock and coil spring that were not compatible with each other which implied to me that the inside diameter of the coil spring was too large for the shock. I’m also confused why you want to spend $43 on an adapter to save $60 on a coil spring.
    Superdave1.0 and OmahTako like this.
  4. Mar 19, 2022 at 2:02 PM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    There's always someone out there trying to do something better to something that's already the best at what it is designed for and make it worse with smartly colored add-ons.
    Just buy the 6112s/8112s.
    Leave the 5100s alone.
    This "mod" is caca!
    ilyace and Superdave1.0 like this.
  5. Mar 20, 2022 at 7:40 AM
    VirginTaco
    2020 trd sport 4x4
    The coils are ground flat on both ends, where as a stock coil is not.
