Coilover help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steve06TRD, Mar 14, 2016.
  1. Mar 14, 2016 at 8:18 AM
    Steve06TRD
    Steve06TRD [OP] Well-Known Member
    RI
    06 DCSB TRD sport
    hey guys, my truck is a 2006 DCSB TRD sport, its in the shop for a new frame and new leaf springs. with the new 4leaf springs, will i need to lift the front? to level it? i need to replace the struts and rear shocks anyway, so i was hoping you guys can provide me some part #'s for a coilover that provides between 1-2 inches front lift.
    \thank you very much
  2. Mar 14, 2016 at 8:34 AM
    Steve06TRD
    RI
    06 DCSB TRD sport
    5100 is that a complete coil/strut? and can i have a link to see 1?
  3. Mar 15, 2016 at 8:39 AM
    Steve06TRD
    RI
    06 DCSB TRD sport
    i have $700 to spend, and i know i need rear shocks, front coils/struts, and brakes front and rear, any help would be AWESOME as i need to get on ordering soon
  4. Mar 17, 2016 at 4:02 PM
    Steve06TRD
    RI
    06 DCSB TRD sport
    sorry to be a pest, i have limited time to order parts before the new frame comes in
  5. Mar 17, 2016 at 4:03 PM
    Steve06TRD
    RI
    06 DCSB TRD sport
    the rear is easy, i need a front assembled coilover thats going to provide between 1-2" lift max in order to level with new rear leafs
  6. Mar 17, 2016 at 5:39 PM
    Steve06TRD
    RI
    06 DCSB TRD sport
    thoughts on rancho? RS9000xl rears? and quicklift loaded struts fronts???? need diff drop??
  7. Mar 17, 2016 at 7:51 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Be aware that some have had the 4-leaf replacements put on with a frame replacement, and the new springs provided -0- lift compared to their old springs.
    See
    Fitz235
  8. Mar 18, 2016 at 4:59 AM
    Steve06TRD
    RI
    06 DCSB TRD sport
    yea i have heard that as well, but was hoping to level the front at minimum. will the Rancho quick lifts be too much?
  9. Mar 18, 2016 at 5:58 AM
    Pigpen
    Dan
    Northwest Montana
    Do Bilstein 5100 adjustable struts set at the .85 (second notch from bottom) as Rock Lobster suggested - with stock coils. You can match with 5100 rear shocks, all for less than $400 delivered to your door. You'll be happy with the look and the ride.
  10. Mar 18, 2016 at 6:08 AM
    Steve06TRD
    RI
    06 DCSB TRD sport
    Is that including springs? & front and rear?? Please provide a website please...
