Coilover Kits vs. "DIY" Suspensions
Discussion in 'Suspension' started by Ihatetacomas, Oct 12, 2014.
  1. Oct 12, 2014 at 11:01 AM
    Ihatetacomas
    Ihatetacomas [OP] Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    I'm having a hard time deciding between fi I should buy a coilover kit or buy the parts individually, for this example ill use the most expensive coilover kit I could find...
    "FOX Ultimate suspension for 05+ Tacoma"
    http://toyteclifts.3dcartstores.com/FOX-Ultimate-suspension-for-05-Tacoma_p_1226.html
    for a low price of $3,300 you could own
    -***FOX Front 880-06-418 extended length front Coilovers with DSC (Duel Speed Compression)
    (1894.95 at weboffroad.com and shockwarehouse.com)
    -***(2) FOX 982-02-366 2.0" Factory Series Reservoir Rear Shocks with CD Adjust ($379.95 at xloffroad.com, $349 at allprooffroad.com)
    -Differential Drop Kit (about $30)
    -ToyTec Progressive Leaf Pack
    (209.99 on bilsteinlifts.com)
    -Rear Axle degree Shims
    (go for about $30 as well)
    -TC 96504 Total Chaos Uniball upper control arms
    (684.55 at wheelersoffroad.com and Amazon)
    So I did some math...
    3,299.99
    -1894.95
    -349 x2 (I did this because the sites I went to only said "shock" not "shocks")
    -30
    -30
    -684.55
    -209.99
    That's -247.5, so all the parts bought separately would equal out to 3547.49, now keep in mind that I didn't look super hard for the best prices for the parts, so if you find better prices please post them...
    Is a coilover kit worth the expense? I would say yes, not to mention that I didn't add shipping expences.
    So that's my writeup xD any questions comments concerns etc. post em.
  2. Oct 12, 2014 at 11:03 AM
    Ihatetacomas
    Dylan
    Elko NV
    Oh and sorry about if I spelled anything wrong, and the font... I couldn't change it after I copied and pasted :(
  3. Oct 12, 2014 at 11:09 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    thx
  4. Oct 12, 2014 at 10:43 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Make it easy on yourself and send a PM to DSM and SDHQ (in vendors section).....have them price you out a package. Diff drop and axel shims aren't needed.
    FRONT
    Coilovers and UCA's
    REAR
    AAL and Rear shocks
  5. Oct 12, 2014 at 11:29 PM
    ProPhaze777
    ProPhaze777 Well-Known Member
    Yakima,wa
    '14 trd offroad black
  6. Oct 13, 2014 at 12:06 AM
    Ihatetacomas
    Dylan
    Elko NV
    Are you sure? Won't the lift cause excessive wear on those components?
  7. Oct 13, 2014 at 12:17 AM
    Ihatetacomas
    Dylan
    Elko NV
    And I ask because this is my first suspension kit iv ever done, and I'd rather not walk into this blindfolded, not knowing what I need. Which I'm catching up on through the suspension forms
  8. Oct 13, 2014 at 4:19 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Keep reading.....the search function here is awesome because everything has been covered 1,058,274 times (or at least close to that number) LOL
    Most of us here know more about our trucks than "Toyota certified mechanics" and you soon will too, if you choose.
  9. Oct 13, 2014 at 11:22 PM
    Ihatetacomas
    Dylan
    Elko NV
    Your killing me here, what's LT?
  10. Oct 14, 2014 at 10:10 AM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
    If you want, shoot me a PM and I can get any of you set-up with a good kit that you can go beat on and not break the bank. We have a TW discount. A properly set-up kit won't need shims or diff drops.
    Let me know what you plan to do with the truck, and budget, and Ill get you best bang for the buck without paying for stuff you don't need,and not spending $ twice.
    We Stock and carry Icon, King, Fox, Camburg, Total Chaos, CST, Bilstein and Deaver.
    -Vince@SDHQ
  11. Oct 14, 2014 at 12:00 PM
    Ihatetacomas
    Dylan
    Elko NV
    is DSC (Dual Speed Compression) a good investment?
    "Duel Speed Compression (DSC) adjuster provides added control and comfort tuning for on-road use while also offering more aggressive damping for use off-road. The adjuster allows for precise suspension tuning with the simple twist of two clearly defined knobs: No tools and no mess, just a way to easily fine-tune your suspension to best suit your needs in any conditions. The DSC increases both low and high-speed compression levels up to 25%, allowing you to maximize small bump compliance and traction while still having the extra damping required for big hits."
  12. Oct 14, 2014 at 1:30 PM
    ProPhaze777
    Yakima,wa
    Vince hooked me up, I've had no negative issues and my suspension performs great, I may upgrade it along the way but I push my truck fairly hard.
  13. Oct 14, 2014 at 8:43 PM
    Ihatetacomas
    Dylan
    Elko NV
    Thank you for recommending them! Now...it's only a matter of picking between the two... :p
  14. Oct 20, 2014 at 4:22 PM
    Ihatetacomas
    Dylan
    Elko NV
    Let me catch whoevers reading this up to speed.
    I priced out both SDHQ and DSM.
    Both were very helpful, SDHQ stands behind ICONS mostly, DSM lets you make your own suspension kit
    SDHQ first:
    Icon Non-resi Ext. travel Coilovers $1299.95
    (FOX 2.5 IFP Coilovers 1294.95)
    Icon or Camburg Uniball UCA $699.95
    (No other option for that individually, using price from DSM
    Camburg 1.25” Uni-Ball UCA’s $664.96)
    Icon 3-leaf AAL $214.95
    (No other option, using DSM pricing for Icon 3-Leaf Progressive Mini-pack AAL $199.99)
    Icon 2.5" resi rear shocks. $719.95
    (FOX Piggyback Shock $899.95)
    Grand Total: $2934.80
    (DSM DIY kit $3059.85)
    DSM:
    FOX 2.5" IFP Ext. Travel Coilover (pair) $1165.45
    (ICON 2.5" IFP Extended Travel Coilover (pair) $1199.95)
    Total Chaos Uni-Ball UCA's $684.55
    (ICON Uni-Ball UCA’s $699.95)
    (compared to ICON AAL from SDHQ for $214.95)
    FOX Factory Series 2.0 Rem. Res. Shocks 1.5-2" Lift (pair) $512.90
    (ICON 2.5 Remote Res. Shocks (pair) $979.90) (keep in mind these are 2.5's)
    Grand Total: $2832.89
    (Icon package grand total $3079.79)
    everything else in () are DSM prices for the same kit on SDHQ and vice versa
    if you want to build your own kit and you don't care if all the parts aren't from the same manufacturer then DSM is your best bet, if your a ICON fan then SDHQ is where you want to go, they have a large selection and pretty much every ICON suspension part you could think of.
  15. Oct 20, 2014 at 5:19 PM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    We can do Fox or King, We just stand behind Icon more since the ride is better with the Mid travel stuff. Also, prices above do not include TW discount from us on the Icon stuff.
  16. Oct 20, 2014 at 7:05 PM
    ProPhaze777
    Yakima,wa
    Which is why I went with icon through SDHQ, plus Cince is all over the boards and they are willing to resolve issues quickly, only personal peril is that I wish I would of known how much I'd be using my truck offroad, probably would have went CDC but that's my fault, then again I probably take it out way more because of the suspension and trying to test my trucks ability now
  17. Oct 21, 2014 at 10:15 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    What terrain are you running? The 2.0 rear shocks should be plenty unless your running fast speed whoops where the shock is cycling through isn't full ROM at fairly high speeds. Could be overkill for you? If you're a weekend warrior and want a softer street ride ask if DSM still does they're free "softer" re-valve for Icons? And what's total shipping going to run you?
    On a side note SDHQ's customer service is second to none so your in win win situation man.
  18. Oct 21, 2014 at 10:26 AM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
  19. Oct 21, 2014 at 11:34 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Lots of options available with the Icon Coilovers! Plus for a limited time I can include a set of SuperBumps with your order.
    [​IMG][​IMG]
    [​IMG][​IMG]
  20. Oct 21, 2014 at 5:07 PM
    ProPhaze777
    Yakima,wa
    I run a lot of different stuff, slow big rocks and logs and muddy trails, fast dry river rock embedded roads/ trails 10" half submerged rocks, and rocky desert type terrain. I don't seem to be bottoming out really, well a couple times, more just need softer all around but still firm on road and right before bottom out, which is why I'm leaning towards some kind of adjustable dampening shock.
