Coilover lengths
Discussion in 'Suspension' started by xmikedentx, Nov 29, 2015.
  1. Mar 12, 2017 at 9:52 AM
    #61
    xmikedentx
    xmikedentx [OP] Well-Known Member
    Yucaipa
    2016 TRD OR White (sold)
    I updated the first post with the Fox 2.0's measurements.
    OK, so you you have the "buy once, cry once" lesson about halfway learned. You dropped $ once on a fashion only lift, and now your topping out when you want function. So now you want to buy again, but only 3/4 ass (slightly more than half ass)?
    If you want the most lift, and most travel (droop in your case), the new King ext and whatever uniball UCA you want. Thats the route I would have went if money was no option, but the Icon kit was several hundred $ cheaper, so thats the route I went. I ended up lifting the front 2", and with the 2" of ext travel the Icon kit gives, i'm sitting at net 0 in regards to up travel and down travel.
    Just throwing a Fox 2.0 on your truck will make it ride nicer, and you can lower your ride height a bit to stop topping out so bad, but now you tires will be rubbing off road. Save up and do it once. Also, you really need to learn how to work on your own rig. Think of all that installer money you can put towards your truck parts instead of labor.
  2. Mar 12, 2017 at 1:25 PM
    #62
    LoneRonin75
    LoneRonin75 Active Member
    2016 Tacoma SR5 Access Cab 4X4
    41.5" Wrap Around Eco-Light LED Light Bar - $215 Using the ZROADZ Bracket - $175 31.5" Eco-Light Bumper LED Light Bar - $150 with a modified bumper mount SST Lift Kit (Leveling Kit) 3" Front and 2" Rear - $350 Custom Light Switch (The switch powers both light bars) - $20 4 BFG All-Terrain TAKO2 LT275/70 R17 - $930 (with hazard insurance and installed) These tires are on the stock (17x7) rims and I have absolutely no rubbing. Replaced the Standard hood with the Sport Hood (with scoop) and painted matching color - $1050 What do y'all think?
    So, what I'm taking away from this is, "learn to do it myself and buy a lot of tools." :). So, extended drive shocks and replace UCA with something worth a shit. I do want to say thank you for getting for the point. Blunt is better.
    AvocadoTaco likes this.
  3. Mar 15, 2017 at 3:17 PM
    #63
    xmikedentx
    Yucaipa
    No prob, lol :cheers: You really don't need a lot of tools to change the arms and coils. Jack, jack stands, and a socket set, and a hammer. An Impact sure makes it nice though..
  4. Mar 18, 2017 at 8:58 AM
    #64
    4x4yotaphan
    4x4yotaphan Well-Known Member
    SoCal
    SOLD: 2016 White TRD Sport DCSB 4x4
    Exterior: King suspension w/compression adjusters Icon billet UCAs Icon 3 leaf expansion pack Timbren rear bump stops w/U bolt flip kit Wheeler’s Offroad front superbumps BFG KO2 285/70/R17 on SCS Ray 10 17” wheels w/black wheel lock lug nuts TRD Pro grill TRD Pro taillights TRD Pro skid plate Demello Offroad front bumper Smittybilt XRC 9.5 comp winch w/Factor 55 fairlead and Flatlink E RCI LCA skids Beast Fab rock sliders 4 Extreme LED 4” pods Baja Design Squadron SAE LED amber fog lights Relentless Fab bedrail mount w/KC Flex dual amber chase lights AVS vent visors Interior: TRD Pro shift knob OEM instrument switch panel conversion (from 3 to 5 slots) Taco Garage DMM with Scosche Magicmount Upgraded Kicker sound system Husky X-act floor liners Performance: Airaid cold air intake system Pedal Commander w/Bluetooth
    Besides droop benefits on the extended travel, are there benefits in getting the standard Kings instead if I'm only lifting the front minimally, for example ride quality? I'm guessing nothing much since both have the same compression specs but wanted to be sure. If there's no benefit then why does King even make the standard? Thanks in advance for the help!
  5. Mar 19, 2017 at 6:05 AM
    #65
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Standard travel coilovers pair well with OEM UCA'S.
  6. Mar 19, 2017 at 6:15 AM
    #66
    4x4yotaphan
    SoCal
    Are there any disadvantages with the extended travel with only using a minimal lift compared to the standard travel? Ride quality?
  7. Mar 19, 2017 at 8:42 AM
    #67
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    I dont know. I chose standard because I have no intentions of replacing my stock UCA'S or lifting beyond 2.5".
  8. Jun 26, 2018 at 4:01 AM
    #68
    IdRatherBNTheSanJuans
    IdRatherBNTheSanJuans Well-Known Member
    Coe
    05 TRD Sport 4x4 DCLB
    Kings. JBAs. AllPro standards. Mastercraft CXT 255/85r16s
    Reading through this thread again, because I got another Tacoma.
    Good stuff! Any updated reviews from the guys on here running the extended coilovers?
  9. Jun 27, 2018 at 4:17 PM
    #69
    dimead0zen
    dimead0zen Well-Known Member
    So Cal
    Mid-Travel 2016 TRD Off-Road 4x4
    Desert prerunnin', rock crawlin' machine!
    In my opinion, no reason NOT to run extended travel coilovers if you are upgrading your upper control arms. No changes in performance on the road, and more droop when you need it.
  10. Jun 29, 2018 at 1:58 PM
    #70
    Coe
    That seems like the case to me as well. It almost doesn’t seem like a +2” long travel is even worth it.
    Any of you guys running the JBA control arms with your extended travel coilovers? From their marketing at least, it seems like they would allow the most travel in an upper control arm. And I like the idea of a sealed joint to protect from corrosion and possibly prevent a little time spent doing quite as much routine maintenance.
    Anybody have more pictures of the extended coilovers working offroad? I am a little on the fence as to whether I should do that or just do an SAC. Can you push me one way or the other?
  11. Dec 29, 2018 at 11:06 AM
    #71
    Shampstar
    Shampstar Well-Known Member
    Aaron
    2015 white trd sport
    What would be travel on these be
    16.72 collasped 22.25 extended
  12. Mar 15, 2019 at 4:18 PM
    #72
    charlieyankee88
    charlieyankee88 Well-Known Member
    2017 TRD OR DCSB MT
    RADFLO Suspension, JBA HD UCAs, Mobtown low pro bumper, Mobtown bolt-on sliders, Engo SR10s, SCS Stealth 6, AFE CAI, URD Spec U, OV Tuned, Gobi Rack, Softopper, CMC
    @Radflo Shocks Extended Tracel UCA version is 22.625 ext with 5.118 travel
  13. Jul 22, 2019 at 3:43 PM
    #73
    Shampstar
    Aaron
  14. Jul 22, 2019 at 3:44 PM
    #74
    Shampstar
    Aaron
    I have the pure performance shocks and they said there front shocks are 15.75” / 22.75” 7inch travel. Am I running a to long shocks and keep having to much down travel and tearing my uca and lca boots.
  15. Oct 31, 2019 at 5:27 AM
    #75
    rcracin
    rcracin Well-Known Member
    Bringing this back from the dead. I have a set of 22” extended SAW 2.5 coilovers lying around and i’m waiting on my SPC upper control arms to come in. I’m assuming this qualifies as extended travel.
    Are oem lower control arms good for this setup?
    Will 22” coilovers be too long and ended up being too compressed, causing damage to the shock?
  16. Apr 1, 2020 at 3:01 PM
    #76
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Ironman4x4 Foam Cell Pro specs for their Tacoma 2005+ kit via their customer service:
    front strut: 22.21" extended and 17.01" compressed; 5.2" of travel
    rear shock: 24.02" extended and 15.71" compressed; 8.3" of travel
    Bilstein B8 8112 specs from Vivid Racing:
    front struts: 22.96" extended and 17.99" compressed; 5.0" of travel
    Bee Finn likes this.
  17. Aug 30, 2023 at 2:33 PM
    #77
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I know this is an old thread, but does anyone know the source of king specs in the first post? They do not agree with specs in this article:
    https://accutuneoffroad.com/oem-front-coilover-shock-setup/
    The compressed length of the king in the first post is 16.75” and is 17.3” in the accutune article, but the extended length is approximately the same in both: 22.6”.
  18. May 23, 2025 at 12:04 AM
    #78
    AvocadoTaco
    AvocadoTaco Well-Known Member
    Cal
    Army green 2022 Tacoma TRDOR
    This is interesting, based on the research I've done, I've thought the 8112 setup to be more limiting on travel.
  19. May 23, 2025 at 12:08 AM
    #79
    AvocadoTaco
    Cal
    Anyone have numbers for the eibach pro stage 2 coilover? I bought my truck with them, but didn't think them to be "extended" travel since they are mounted with the stock UCA. I recently got a set of the ext icons, and I'm surprised to see that the coilovers are very similar in extended length, and I dare say, eibach is slightly longer than icon? Can someone confirm? If they are, then it's impressive they nailed the fitment with the stock control arms and a good alignment, albeit barely in spec at 2" of lift.
    Also, what would be the stock eye-to-eye for trdor? I think we'll have a pretty complete thread after this.
