Coilover Problem!!!
Discussion in 'Suspension' started by ETaco23, Mar 30, 2009.
  1. Mar 30, 2009 at 6:58 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I was out in the shop trying to adjust my coilovers, bc they are off, one side to the other... But I cant get my driver side to crank... It sooper hard and wont budge, I can get it to go down fine! So is there something I can do to get it to budge, becides taking my coilover off and doing it in a vise?:mad:
  2. Mar 30, 2009 at 6:59 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    New Bern NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    Are you taking the weight off of that side of the truck when you do it?
  3. Mar 30, 2009 at 7:00 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    they have to be taken off of the truck I believe....
    or atleast jack it up to there's no stress on them
  4. Mar 30, 2009 at 7:02 PM
    jolayiv
    Jim
    New Bern NC
    No need to take them off, just take the weight off.
  5. Mar 30, 2009 at 7:04 PM
    ETaco23
    Evan
    PNW
    Yeah I got the truck jacked up! I have done this before, with them on the truck, its not that hard, but for some reason it wont budge on the driver side.
  6. Mar 30, 2009 at 7:05 PM
    canuck_tacoma
    canuck_tacoma Well-Known Member
    BC, Canada
    SR5 4X4 Tacoma Access Cab
    1.5" Eibach Front Coil Lift, Rear TSB, 265/75/16 BFG A/T's
    That coil is still going to be loaded in the strut even with the truck jacked up.
    How old are your coil over's? If they are fairly new then they shouldn't be siezed. Try hitting the spanner nut with a torch, be careful not to over heat the shock and spring. If you do it just right you will expand the nut before the strut expands and loosen it.
    If that doesn't work. Hit the spanner nut with the torch then spray some penetrating lube in there before it cools. Just don't have the flame there while you spray or it will be a bigger torch.:bananadead:
  7. Mar 30, 2009 at 7:05 PM
    jolayiv
    Jim
    New Bern NC
    Are the threads pretty good and clean? Try cleaning them up a bit if not.
  8. Mar 30, 2009 at 7:16 PM
    ETaco23
    Evan
    PNW
    Yeah, there clean. My coilovers arent that old. Maybe a month... I dont know If im ready to torch my C/O.... Ive done this before with no problems. piece of pie!!! I tryed lubing it, but nothing!
  9. Mar 30, 2009 at 7:28 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Hold the spanner wrench on the coil-over and hit the spanner wrench with a dead-blow hammer. It's slow going but it'll work.
  10. Mar 30, 2009 at 7:30 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    BFH works every time
  11. Mar 30, 2009 at 7:36 PM
    canuck_tacoma
    BC, Canada
    If you're not comfortabe with it then do it as a last resort. It does work well. A regular hardware store torch works great, just hit it quick, a couple of seconds just to expand the spanner nut. Like heating up a metal lid on a glass jar.
  12. Mar 30, 2009 at 7:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Another thing you may want to consider. AS your truck is on a lift, take the Co's off, remove the pring from them, and apply some anti sieze along the threads. Its a bitch, as you have to dismantel them, but it will prevent this from happening in the future, and they will be able to be adjusted easily.
  13. Mar 30, 2009 at 7:51 PM
    ETaco23
    Evan
    PNW
    Well, I think I will try the hammer trick first. I'll see what I can do tomarrow..... I dont have far to go, so thats a good thing!
    thanks for all the help and seggestions guys!
  14. Mar 31, 2009 at 12:37 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    do 10 reps of 400lbs on bench press,10 reps of 75lb barbell wrist raises for your forarms and go for it.just dont break the spanner wrench.i works everytime.
  15. Mar 31, 2009 at 5:46 PM
    ETaco23
    Evan
    PNW
    ^^^HA! yeah, I think I would be dead, seeings how I cant rep 400lbs..
    But I got it figured out. It took some perswation with a hammer and lots of grunting, but I got both side at 38-3/4" and my rear is at 39-1/2. So a 3/4" rake is pretty good. :)
