Coilover Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Isaiasgon, Nov 2, 2011.
  1. Nov 2, 2011 at 2:13 PM
    Isaiasgon
    Isaiasgon [OP] Well-Known Member
    GA
    2013 4x4 TRD Sport V6 DCLB
    This may be a dumb question but ill ask it anyway because im curiouse, Does anyone know what will happen if crank my coilovers lift more than 3' inches from the spring to the top part of it?
  2. Nov 2, 2011 at 2:20 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
  3. Nov 2, 2011 at 2:21 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    You'll have no suspension droop and your truck will ride really poorly.
    Rather than having a wheel drop into a pot hole, the whole corner of your truck will drop because the lower control arm won't be able to drop any more than it already is at ride height.
  4. Nov 2, 2011 at 2:22 PM
    Isaiasgon
    GA
    Like to lift the front end higher
  5. Nov 2, 2011 at 2:23 PM
    Blackshirts
    TX
    09 PreRunner
    Stuff
    Get some ome 885 that will lift your truck up to 2 to 2.5
  6. Nov 2, 2011 at 2:29 PM
    Isaiasgon
    GA
    So lifting the front end by cranking up the adjustable coilovers to bring the truck up is a bad idea? The reason is because i just want to level the truck up with out adding more stuff to it.
  7. Nov 2, 2011 at 2:54 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    just don't go over 3" of lift with the coilovers.
  8. Nov 2, 2011 at 6:58 PM
    Isaiasgon
    GA
    Thank you
