Coilover question
Discussion in 'Suspension' started by SilverSeven, Jan 8, 2009.
  1. Jan 8, 2009 at 6:23 AM
    SilverSeven
    SilverSeven [OP] Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    Alright, I just got some COs and was wondering, when they are still in the box, are they at full droop? or will there be more droop when on the vehicle?
  2. Jan 8, 2009 at 6:27 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    hmm... I imagine they're at full droop in the box, but I could be wrong.
  3. Jan 8, 2009 at 6:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Yeah, Dude. They are at full extension.
  4. Jan 8, 2009 at 6:34 AM
    SilverSeven
    Jordon
    South Jurzee
    ok, well no heres my next question, I measured roughly from the top plate, to the eyelet of my new CO and it was ~27"
    I also measured roghly the top plate to the eyelet on my current set up already on the truck and it was like ~26.5" and thats under load!
    So My question is, how am I going to get any droop if the COs are at full extension?
    note: I have no idea how the COs are cranked right now
  5. Jan 8, 2009 at 6:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats what happens when you are lifted too much. The front suspension has a fixed amount of travel. Even with a Drop bracket lift. When you lift, say 3" up, you loose 3" down travel.
  6. Jan 8, 2009 at 7:07 AM
    SilverSeven
    Jordon
    South Jurzee
    yeah, but these Cos are meant for this lift, they are supposed to be longer. I can see if I had them cranked all the way up, But I think I am missing something, because even stock I have droop, the way I am seeing this as putting these COs on will actually diminish droop..
    That cant be right, or can it?
  7. Jan 8, 2009 at 7:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just because they are "meant" for that lift(which, by the way, is something Pro Comp likes to say about their products), doesnt mean they will increase travel. As you are right now, you probably only have 1" of down travel. I think with the CO's you will be the same. The only way to get more travel, is to go LT, which means different LCA's, and UCA's, and being 4x4, new DS. A Drop bracket lift doesnt give you anymore travel no matter what kind of Co's you use. The limiting factors is still going to be the suspension geometry, and the legth of the CA's.
  8. Jan 8, 2009 at 7:16 AM
    SilverSeven
    Jordon
    South Jurzee
    Right, So I understand its not LT, but I guess what I am trying to figure out is if my travel will be the same as stock, I mean some 3" guys get droop right? or is the 3" kit still only getting like 1" of droop?
  9. Jan 8, 2009 at 7:19 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    travel will be a little more than stock, as you have the Camburg UCA's. If the CO's are "extended length", then you will get more travel. Same with the 3" lifts. Unless they have new UCA's to allow for more droop, then they are takeing the lift from the down travel.
