Coilover Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1998tacoma4x4, Jan 18, 2010.
  1. Jan 18, 2010 at 10:20 PM
    1998tacoma4x4
    1998tacoma4x4 [OP] Well-Known Member
    Orange County
    1998 Tacoma 4x4 3.4L Auto
    Deaver j59 pack 2.5 SAW coilovers, rear bilstein 5100's. Extened stainless rear brake line, deck plate mod, drop in K&N filter, Kenwood headunit & pioneer speakers, SnugTop Shell.
    I found a pair of Race Runner coilovers on RDC and i am planning on getting them but they are lifted a little too high for my liking. How do i go about adjusting them? Do i just use the spanner wrench to lower them or is it more complex than this? Any input appreciated.
  2. Jan 18, 2010 at 10:28 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Bump. (I am curious too.)
  3. Jan 18, 2010 at 10:34 PM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    I don't know about Race Runners, but most adjustable coilovers are pretty much the same. My Icon's just have a lock screw that gets loosened and then I just use the spanner wrench to adjust the "collar" above the spring, then lock it back into place. Some coilovers have two collars that act as lock nuts once adjusted and re tightened . Keep in mind clearence and your ball joint angles as well if you adjust while they are installed. Hope this helps.:cookiemonster:
  4. Jan 18, 2010 at 10:34 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    spanner wrench...
    make sure they are stock replacement coilovers or i believe 6.5" stroke coilovers...
  5. Jan 19, 2010 at 11:35 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    jack the truck up off the ground, loosen the set screw, turn collar with spanner in the direction you want, retighten set screw and your good to go. sometimes it can take alot of force to turn the collar. they get kinda tight, i just spray alot of WD 40 like 15 min before and it works well for me.
  6. Jan 21, 2010 at 11:27 PM
    1998tacoma4x4
    Orange County
    Ya they are the stock replacements. Thanks again everyone for all the help!
