coilover questions
Discussion in 'Suspension' started by kam, Nov 16, 2010.
  1. Nov 16, 2010 at 11:18 AM
    kam
    kam [OP] Well-Known Member
    Fullerton
    04 1st Gen. Extended Cab
    some of you already know i have been back and fourth with lifts.. i have a 1st gen prerunner. i'm gonna take the bullet and get coilovers.. the coilovers i'm looking at are the icons or even kings... i hear the icons are made just for tacoma trucks.. not to sure about the kings.. now for the rear whats the big advantage with the reservoir? here is a link to the icon lift i'm looking at. http://www.iconvehicledynamics.com/...=96%2d04-Tacoma-Suspension-System-%2d-Stage-2
    now with the icons am i going to be able to take a decent load in the back? couple of dirtbikes?
    basiclly my questions are as follows...
    is this lift going to be making the truck sit even?
    how are the coilovers with an off road bumper up front?
    say i want about 3 inches wider stance up front how can i obtain that?
    will i be able to get about 3 1/4" lift from the front without new uca?
    another question i have is what is the difference between standard and extended travel?? i'm guessing that the extended travel setup is for people with long travel setups?
    PS - about 6 months down the road i will end up getting new UCA
    the reason why i'm going back and fourth is because this is a nice chunk of change for a college student.. i wanna make sure i don't just toss my coins out there.
    i also really appreciate all of the help that i have already gotten...
  2. Nov 16, 2010 at 11:30 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Any shocks with resi's will not fade as quickly or at all. It is all about how hard you run the shocks.
    Coilovers will run softer with a offroad bumper (heavier ones) and will decrease the lift therefore requires more preload.
    3" with a wider stance means you need to either get wheels with more BS to stick out further, get wider tires, or get wheel spacers.
    why do you want more than 3"? that will give you a shitty ride because your limiting your down travel. (unless you go with extended travel and UCA's)
    standard = stock travel. extended travel can yield ~.5 to 1" increased travel with proper UCA's. No extended travel is not for LT, LT shocks are for LT.
  3. Nov 16, 2010 at 3:05 PM
    kam
    Fullerton
    so would i be able to go with the extended travel setup without replacing my uca's right away?
  4. Nov 16, 2010 at 3:07 PM
    kam
    Fullerton
    also will that aal in that link be able to support a nice size load?
