Coilovers an absolute must?
Discussion in 'Suspension' started by 06tacomakev, Jan 13, 2012.
  1. Jan 13, 2012 at 9:30 PM
    06tacomakev
    06tacomakev [OP] Well-Known Member
    Kev
    Victoria BC
    2003 tacoma 4x4 dblcb
    I have it down to the OME and the Toytec suspension offerings. With either one I will replace the UCA.
    I will also be getting new rear springs. I will not be racing my truck but it will be offroaded on weekends. Some mild some moderate.
    What are new coilovers going to do for me that a regular shock will not?
    The basic difference between my two options has come down to the coilovers
    Thx in advance the advice I am getting from this forum has been very helpful
  2. Jan 14, 2012 at 6:12 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    You kind of swapped what you were asking, you start asking about the coilover then switch to asking about the shock. An aftermarket coil will be taller and usually stiffer than the stock coil so you'll get lift and more stability (plus greater resistance to bottoming out on bigger hits). Aftermarket shocks are valved to dampen the taller and stiffer coils. Your stock shocks will not last long with a stronger coil.
  3. Jan 14, 2012 at 8:09 AM
    06tacomakev
    Kev
    Victoria BC
    Sorry I will try to clarify it better.
    A sealed coilover unit seems pricier than just a new shock and spring. OME comes with new shocks and spring choices. The toytec comes with true coilovers(adjustable)
    Is it just the adjustablity factor that you get with a product from toytec, icon, or king and such?
    And thank you, you did answer one part of my question
  4. Jan 14, 2012 at 4:07 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Toytec is an eibach spring and 5100 shock, I wouldn't call it a true coilover like icon, fox etc. Yes it has an adjustable collar and are great for light to moderate trails so depends on your use! I'll still end up going to a higher quality coilover due to my style of wheeling, might as well have the best bang for your buck. The extra down travel, better compression/rebound and re-buildable/re-valvable does make it worth it in my opinion. I do really like my toytecs but feel the higher end coilovers are tuned much better for off road.
  5. Jan 14, 2012 at 4:25 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    One is assembled and comes with the top. The other only has a coil and strut; you have to reuse your top. You also will need a spring compresor.
  6. Jan 14, 2012 at 4:36 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    ^^^ Good point, if you were looking at the assembled one that's adjustable at $800 or whatever def get some ICONS non-resi. The assembled non-adjustable one for $600 is a more cost effective way to go. AAL, rear shocks and UCA and your set for just over 1k!
  7. Jan 14, 2012 at 5:20 PM
    06tacomakev
    Kev
    Victoria BC
    thx sublime and skytower,
    that is what I was wondering. Good explanation
  8. Jan 14, 2012 at 5:56 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Anytime buddy! Keep us updated!
