Coilovers vs ome lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sanchostaco, Dec 24, 2016.
  1. Dec 24, 2016 at 7:55 AM
    Sanchostaco
    Sanchostaco [OP] Well-Known Member
    Josh
    2004 tacoma trd
    Stock
    I got a 2004 tacoma double cab trying to decide between coilovers or the ome setup tha
  2. Dec 24, 2016 at 8:04 AM
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    Depends on your budget and whether or not you want the adjustability that comes with C/O's.
  3. Dec 24, 2016 at 10:18 AM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    How do you use the truck, budget, needs would help decide
  4. Dec 24, 2016 at 10:29 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    No reason to put coilovers on a stock ifs truck unless you like watching money burn or feel like you have to look cool for TW. Go OME or bilstein struts and call it good. Your ball joints only cycle about 7 inches of travel so you aren't running any real high speed that will warrant c/o's.
    C/O's also require maintenance and will corrode if you live in the salt belt. Struts you just put on and forget
  5. Dec 24, 2016 at 11:12 AM
    Sanchostaco
    Josh
    2004 tacoma trd
    Stock
    I'll be going to moab and trail use i didn't think about the salt are the bilstien struts just as good as the ome coils
  6. Dec 24, 2016 at 11:17 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I'd use Bilstein shocks and OME coils.
  7. Dec 24, 2016 at 11:24 AM
    Sanchostaco
    Josh
    2004 tacoma trd
    Stock
    I'll have to go that route
