Coilovers
Discussion in '1st Gen. Tacomas (1995-2004)' started by old grouch, Aug 21, 2020.
  1. Aug 21, 2020 at 6:43 AM
    old grouch
    old grouch [OP] Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    2004 DCSB 3.4. Is there an aftermarket coilover assembly (don't want to assemble it myself) that will NOT provide ANY lift? I would even settle for coils & shocks separately & pay to have them assembled. Did you note the part about NO LIFT? Can anyone give me a definitive answer? Toyota dealership says Access Cab & DC have different part numbers. All the places I have looked online only show Std Cab or Access Cab applications. I just can't believe no one makes stock height coilovers for this truck. So if you know of a part number or a website for what I want please post it. TIA
  2. Aug 21, 2020 at 7:06 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  3. Aug 21, 2020 at 8:17 AM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
  4. Aug 21, 2020 at 10:30 AM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Do you want coilovers or a standard stut and spring? Quick strut, or ready strut? They come assembled.
    Replacing the spring might give you a minimal amount of lift, if you currently have tired springs.
  5. Aug 21, 2020 at 1:53 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Many retailers confuse the two terms, but they are all coilovers. Even the OEM ones.
    Clearwater Bill and Wyoming09 like this.
  6. Aug 21, 2020 at 5:02 PM
    Old green toyota
    Sacramento,CA
    Oil leaks
    I understand they are synonymous, but in this situation it helps to know exactly what he is looking for. The term stock height aftermarket coilover kind of sounds like hes looking for something not OE replacement.
  7. Aug 21, 2020 at 5:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    5100s on 0, OE springs.
    Pay to have them assembled.
    0xDEADBEEF likes this.
  8. Aug 22, 2020 at 4:01 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    I did the Monroe 171352L/R on my ‘04 4-cyl extracab back in January and I’m pretty happy with them. My use case is occasional puttering around town and the rare short highway cruise to blow the dust off. As much as I like how the Monroe’s restored the ride height and improved the ride something makes me think that the spring rate that worked for me would be too light for a 6-cyl and/or a double cab.
  9. Aug 22, 2020 at 5:51 AM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    To clarify, I am planning to do a full suspension refresh, front & rear. I just want new coilovers that are stock ride height. I am pretty sure the monroe "quick struts" would be adequate for normal city/highway driving but I do a fair amount of off road stuff & my concern is that the springs might not be strong enough for the additional weight of the DC. I could go OEM but hate to spend that kind of money. If I went with Bilsteins, what shock would I want? And what brand spring? Part number?
  10. Aug 23, 2020 at 2:43 PM
    jbrandt
    Justin
    They aren't synonymous. They are different.
    A strut is an integral part of the suspension geometry. A coilover just supports the weight. The stock shocks are coilovers.
  11. Aug 23, 2020 at 2:47 PM
    jbrandt
    Justin
    For stock height go with the 4600s (Bilsteins), front and rear. Technically in the front, you can run the 5100s at stock height too, but the rear 5100s are longer and require a 1"lift or more. For coils, Moogs are a good choice. Honestly, the OEM coils aren't all that special.
    Just kinda depends on how much off roading you do. If you consider off roading just driving down some gravel roads, the Monroes I'm sure would be fine, they are more oriented for highway travel, but a few gravel roads here and there won't kill them.
    cast718 likes this.
  12. Aug 24, 2020 at 6:36 AM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    jbrandt -- I do quite a bit of off roading. We try to make at least one multi-day trip a a month. Did the Alpine Loop and Stony Pass out of Lake City last week. Have been to Moab several times. Also some stuff around Sedona, Tucson, Bullhead City. I have the Rancho 9000 series coilovers, which add 1 3/4" lift, on my 95 and they have held up well. But I really don't want the lift on this truck. I forgot to mention I have a 3/16" stainless skid plate & may add a winch so maybe should be looking for some beefier coils instead of stock? Any suggestions? Thanks
  13. Aug 24, 2020 at 9:26 AM
    cast718
    cast718 Well-Known Member
    New Jersey
    2004 4WD Standard Cab 4 Banger
    I'm with @jbrandt on this one.
    Once you get tired of all the internet research and hemming and hawing and thinking about it, get Bilstein 4600 front and back, and some MOOG coils. This is the exact setup i have on my truck and its great. If you are concerned about the extra weight of the cab for the stock coils (MOOG), then maybe look into some OME coils. Depends on your budget really. My Moog coils were like $80 shipped.
    I paid my local shop $40 to assemble the coils onto the shocks with new top hats and would do it again in a heartbeat.
  14. Aug 24, 2020 at 10:09 AM
    jbrandt
    Justin
    "beefier" coils is not really a thing unless you want a lift, or heavier spring rates. And you don't necessarily want heavier spring rates for off roading.
    The 4600's and the 5100's are pretty much the same shock, the 5100s are just height adjustable.
    With that amount of dirt driving, a set of OME 880's, some 5100s, and maybe a 1" lift shackle in the back would work nicely. You'd barely notice the lift.
    Here's mine with a ~1" "lift".
    jammer likes this.
  15. Aug 25, 2020 at 6:51 AM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    Thanks guys. Looks like I will go with Bilsteins & Moog coils when the time comes.
    jbrandt likes this.
  16. Sep 26, 2020 at 11:54 PM
    waseemri
    waseemri Active Member
    Waseem
    1999 Toyota Tacoma sr5 v6 4wd xtra cab
    IF you want stock height and don’t want to spend money there is a difference in spring rate from 4cly to v6 4wd but any where you go they only have one shock available for any model I now this bc I installed them and my truck sat 2 inches lower so I did a little digging and went bought shock for a 99 4Runner 4wd V6 and installed them and the ride height is perfect got the stock height back I don’t know why this issues hasn’t been resolved by aftermarket manufacturers
