Coils? 5100's w/ stock or eibachs coils
Discussion in 'Suspension' started by Jeremy92, Jan 31, 2011.
  1. Feb 1, 2011 at 11:43 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    How much lift did you get out of the Eibach's? Sounds like it was less than an inch. If that's the case, I'm sold!
  2. Feb 1, 2011 at 11:58 AM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    I gained 2" with the Eibachs and 1/4" spacer. Rear TSB gain was about 1 3/8". Its been about 3 months and nothing has changed yet. Remember, this is a 4x2 so mileage may vary.
  3. Feb 1, 2011 at 12:23 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    IMO it think it's best to be a little higher in the back for a truck. Especially if you use your bed at all.
  4. Feb 1, 2011 at 3:18 PM
    Jeremy92
    Jeremy92 [OP] Tennessee Member
    Jeremy
    Smyrna, TN
    08 AC SR5 Prerunner Impulse Red
    Billies on all the way around, w/ Eibach Coils, w/ rear TSB. Brush Guard. Tail Light Guards.Window Rain Deflectors. 35% tint on side windows. Satoshi Grill(thanks TacoAlaMode). Fog Light Mod (thanks lifesaflaw123). 17x9 XD addicts wrapped in Kumho SAT Kl 61's 265/70/17.More to come!!!
    agreed because there is a reason they made it that way at least on the prerunners. But I have a brush guard on the front and that would weight down the front alittle. I just don't want the ass end a mile higher than the front, where it is really noticeable.
  5. Feb 1, 2011 at 3:23 PM
    Jeremy92
    Jeremy
    Smyrna, TN
    And just to be totally clear you have done nothing other than get the rear TSB done to the back.
  6. Feb 1, 2011 at 6:35 PM
    RLDTACO
    Bob
    Houston Tx.
    Rear TSB and 5100s, but there was no gain going from stock shocks to Bilstein 5100s.
  7. Feb 1, 2011 at 6:44 PM
    LouTaco
    LouTaco Well-Known Member
    Lou
    Des Moines, Iowa
    2010 MGM DCSB TRD Sport 4x4
    5100's, OME 885X coils, Top plate spacer kit, TC UCA, TSB Leaf pack w/ 1.5" TSB AAL and 1/2" block, Weathertechs, BHLM w/ Retrofit, Foglight Mod, Illuminated 4x4 switch, 18" Wicked Flow, AP U-bolt flip kit, DTLH w/ URD O2 sim, SCS Stealth 6 wheels, 285/70/17 TG G2, ImMrYo bracket
    [​IMG] Very nice ride with this set up. I had Billies set @ 2.5 with stock coil and it was pretty stiff, but OME is a softer ride imo.
  8. Feb 2, 2011 at 6:35 AM
    Jeremy92
    Jeremy
    Smyrna, TN
    Thank guys, now I'm going to have to choose between getting the OME or Eibach's, I'm for sure not gonna use the stock coils, because i would rather not preload the springs. I'll just use the coils to do the lifting. So now the new question get the OME's or Eiback's??
  9. Apr 26, 2011 at 3:57 PM
    willimatic
    willimatic Well-Known Member
    Will
    Rancho Murieta/Folsom, CA
    06 Tacoma AC 4x4 Sport
    What did you decide on? I am in similar boat right now!
