coincidence?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kurts74, Jul 25, 2024.
  1. Jul 25, 2024 at 6:58 PM
    kurts74
    kurts74 [OP] Well-Known Member
    Flagstaff, Arizona
    2nd Gen 4-door longbed
    ICON Mid travel set up with Hard candy shell
    So I'm in for an oil change at Valvoline and while I'm there I have them do the front differential. Drive 5 miles home and park the truck for a few days and then see a leak underneath. Fluid coming from the axel appears to be an issue with seal. Any chance they jacked something up? Seems weird no issues, shop touches it, drive home and now leaking. They didn't need to lift the truck to do the work so it seems like a coincidence, but I don't like believing in coincidences.
    Thanks.
    HondaGM likes this.
  2. Jul 25, 2024 at 7:02 PM
    mk5
    mk5 Asshat who reads books
    SoCal
    '05 access cab 4x3
    Could be an overfill fill issue, I did that once and it gummed up the breather, clogging it, then blew out the axle seals.
    Check for oil coming from the breather tube next to the battery.
    But also... axle seals wear out, and fluid changes can make them leak faster. So could be natural.
    GilbertOz, HondaGM and TnShooter like this.
  3. Jul 25, 2024 at 7:28 PM
    Homeline
    Homeline Well-Known Member
    2013 Access Cab 5-Lugger
    2" Leveling Kit, TRD skid plate, 16" Jeep wheels, Katzkin leather seats w/heaters, jump seat delete
    Some possibilities.....
    They were sloppy and it's residual fluid dripping off the axle.
    Is plug tight? Cross threaded? Present?
    Maybe you had seal almost ready to fail. By putting correct amount (or too much) fluid has caused seal to fail.
    Crawl under with a light to inspect. Clean off with carb cleaner, drive it and check again.
    HondaGM likes this.
  4. Jul 25, 2024 at 7:30 PM
    Bishop84
    Bishop84 Well-Known Member
    It might have been slightly low before and its slightly high before.
    It's not uncommon to see the side seals leak. Especially after 10 years.
    winkel and HondaGM like this.
  5. Jul 25, 2024 at 7:37 PM
    TacoTuesday1
    SD CA
    No
    Shelf Life, Black97v6MT and HondaGM like this.
  6. Jul 25, 2024 at 8:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    How do you overfill a diff?
    ToyoTaco25 and Dm93 like this.
  7. Jul 25, 2024 at 8:05 PM
    kurts74
    Flagstaff, Arizona
    Thanks I will check the breather.
  8. Jul 25, 2024 at 8:08 PM
    kurts74
    Flagstaff, Arizona
    I slipped some folded paper towel in the gap between the axel and definitely picked up oil there. The plug is tight and is seated well.
  9. Jul 25, 2024 at 8:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  10. Jul 25, 2024 at 8:11 PM
    kurts74
    Flagstaff, Arizona
    I know...should have just done it myself. I bring our work trucks there because they seem to do a good job so I thought time to save some time and spend some money. Might not be their fault, but now I won't be saving time or money and I would have know exactly what happened had I did the work.
  11. Jul 25, 2024 at 8:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Jacking up only the drivers side to access the fill plug through the drivers wheel well.
    Fluid runs down the axle tube on the passenger side. Once the truck is "level", the fluid that ran down the passenger side axle tube runs back into the diff, which is now "over full".
    I always recommend jack stands on both sides. Or all 4 corners for the perfectionist (I am not, 2 in the front work for me).
    jubei and winkel like this.
  12. Jul 25, 2024 at 8:22 PM
    TnShooter
    Deogee
    STOCK
    You can look at it in a positive way. At least they got the drain plug out for you. :rofl:
    That plug has been known to make a 15 min job, turn into a 2 hr job.
  13. Jul 25, 2024 at 8:38 PM
    Bishop84
    Most manufacturers want it 1mm below the fill hole.
    Honestly I plug it while its trickling so I can visibly see its been filled. I need confirmation when I'm in zombie fluid mode.
    When I'm feeling precise I use a zip tie to see if the fluid is set correctly.
    Black97v6MT likes this.
  14. Jul 25, 2024 at 8:41 PM
    kurts74
    Flagstaff, Arizona
    Geez. Hopefully when I replace the seal and top off the gear oil the plug only takes me an hour. I
  15. Jul 25, 2024 at 8:43 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'm assuming Valvoline wasn't doing the fluid exchange on a jackstand in the parking lot but who knows..
    Dm93 likes this.
  16. Jul 25, 2024 at 8:44 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    :rofl:
  17. Jul 25, 2024 at 8:45 PM
    TnShooter
    Deogee
    STOCK
    I doubt it.
    But I was just saying "How it can be done".
    b_r_o[QUOTED] likes this.
  18. Jul 25, 2024 at 8:48 PM
    TacoTuesday1
    SD CA
    K. Front diff fluid change.
    1st of all. Change drain plug washers with genuine parts. Do they stock that? No.
    2. Clean any residual spill with brakleen. Do they do that? No.
    I would say you can spray leak detection spray, after a cleaning, to observe. But that is something one does after a job has been done properly, not improperly.
    If it is done improperly, you will have a leak and need to do it properly.
    This can be done on the floor outside.
  19. Jul 25, 2024 at 9:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Oh I know, I'm just being snarky
    It's possible they just slopped oil around filling it. I'd clean it up and monitor
    TnShooter[QUOTED] likes this.
  20. Jul 25, 2024 at 9:13 PM
    TnShooter
    Deogee
    STOCK
    Yeah. It's possible.
    Brake clean and a rag seem to be hard to come by a quick lube shops.
