Cold air from heater
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tmar04, Nov 7, 2024.
  1. Nov 7, 2024 at 3:27 PM
    Tmar04
    Tmar04 [OP] Well-Known Member
    Terry
    2004 Tacoma prerunner
    I get cold air(refrigerated) when heater is on . Coolant temp 184,(normal) turn on heater and blows cold air! Heater valve working, heater core flushed and clean, no leak from heater core, just cold air. A little warmer when vent is on floor heat. Not much better, but a little. It almost seems a/c comes on when heater fan is turned on! Can that be possible?
  2. Nov 7, 2024 at 3:28 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Might be a blend door actuator
  3. Nov 7, 2024 at 4:59 PM
    jweekes
    jweekes Member
    2001 silver Tacoma double cab
    I second that. I've never had this happen on my tacoma, but I had the same problem in an old suburban. Ended up being the HVAC control module not activating the blend door. Listen for it in the dash when you adjust the temperature. If you can't hear it then you could probably investigate further with a multimeter. If it is blowing at AC temperatures (colder than outside) that would be strange and I'm not sure what would cause that.
  4. Nov 7, 2024 at 5:55 PM
    Tmar04
    Terry
    Thanks. Gonna check out blend door
  5. Nov 7, 2024 at 6:02 PM
    Squirt
    Ben
    I've had 2 of them go out on my F150 and had similar symptoms. One was the temp control for the drivers side. I'd have hot air blowing on the passenger side and ice cold on the drivers side. Second one was the panel control so it wouldn't switch from feet to defrost or switch at all.
  6. Nov 8, 2024 at 3:06 AM
    Tmar04
    Terry
    And what was remedy?
  7. Nov 8, 2024 at 4:25 AM
    Squirt
    Ben
    Just replacing the blend door actuators for those specific functions
  8. Dec 11, 2024 at 3:31 PM
    Tmar04
    Terry
    Update: I replaced water pump, which appeared original, with new Aisin pump and all is well with heater now. Heater core just wasn’t getting enough flow. What a difference!
