Cold air in center console
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cement_wheels, Dec 27, 2022.
  1. Dec 27, 2022 at 4:02 PM
    Cement_wheels
    Cement_wheels [OP] Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Why is there so much cold air coming in through the center console. I have a key ring that I can disconnect from the fob so they are not swinging all over the place. I put them in the center console organizer and when I take them out they are ice cold. Also, because it's been so cold, it seems like it's coming in through the dash in a few places.
  2. Dec 27, 2022 at 4:07 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    cause it's a cooler
    I don't know really, I suspect there isn't carpeting and insulation under it, or you have something leaking. I haven't notice cold air blowing from that area.
  3. Dec 27, 2022 at 4:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    Was the truck cold when you entered? If so, it's just retaining that longer. Being closed it won't warm as fast as the cab.
    As far as the other air, do you have your climate set to recirculate? If not, you are drawing fresh air.
    Bet if you had a couple hour road trip, the kind you either turn the heat down or your jacket off, the console would be just fine.
    Jacpring, Cement_wheels[OP] and hiPSI like this.
  4. Dec 27, 2022 at 4:14 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If you check in the back floorboard or under the back seat it is the same. Heat rises so it is going to be cold in confined spaces and down low. It is what it is.
