Cold Air Intake (CAI) Options:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StuckinOhio, Sep 9, 2012.
  1. Sep 12, 2012 at 3:59 PM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    That is why I simply said if you plan on offroading it, you might want to stay away from the intake because it is exposed right behind the grill. If it was a mall crawler, like mine, or an x-runner, I would have said get the URD and have some fun. But why risk it?
  2. Sep 12, 2012 at 4:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It all depends on the off roading. IIRC, URD has a cover to place over the filter so as to keep more dust out.
  3. Sep 13, 2012 at 6:36 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    FYI, my experience with the Afe SI was the same. Same results too, back to stock, and now have a URD+Maf waititng to be installed.
    Do note though that intake noise and exhaust noise are very subjective. What works for one, doesn't for another and vice-versa. Everyone has their own sense of style, and ears in this case. "Everyone" said that the TRD exhaust is mellow and non-intrusive. I tried one and removed it within 2 weeks. Personally I have little tolerance for resonance (wife has ZERO tolerance), and I had resonance in the 2500rpm range, back to stock on that one to. Thinking about a Dynomax or an Aeroturbine, but haven't pulled that trigger yet.
  4. Sep 13, 2012 at 7:18 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Same as what wolfpack and lurkin said. The resonance inside the cab is horrible imo. Which is why I'm going to the gen2 intake. Definitely not putting on an exhaust either. Had an exhaust on my 06 Taco and the drone was bad.
    Unfortunately lurkin, that aero is going to be just as bad.
    I can't wait to make this switch tomorrow.. if I don't throw any codes, I'll be keeping it and will post results
  5. Sep 13, 2012 at 7:45 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Huh, even the XL?
  6. Sep 13, 2012 at 7:54 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    The 2525 right?
  7. Sep 13, 2012 at 9:05 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Kind of, I was thinking of the 2525xl, the resonated one.
  8. Sep 13, 2012 at 9:12 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah. Same thing basically. The xl will be a little less raspy.. but its still gonna drone like any exhaust.
  9. Sep 14, 2012 at 9:40 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Well, just replaced my AFE Stage 2 with the Gen2 TRD intake. I already love it. Not nearly as loud, bit still a nice growl when accelerating. At WOT it Isnt as raspy nor does it have the resonance that the AFE had. I also feel (by butt dyno) that it has more torque and pulls harder. I'll keep an eye on it for CEL's , but so far so good. I'm definitely a lot happier with the TRD than the AFE.
  10. Sep 14, 2012 at 10:31 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hahahaha.. Yeah. just giving some honest feedback. :p
  11. Sep 21, 2012 at 9:29 AM
    StuckinOhio
    StuckinOhio [OP] Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    So I know this thread is pretty dead anyways but, if i was what to get a CAI what would you suggest? Im sort of leaning towards an airaid. Hows filtration compared to stock? Im in NE ohio so NO desert dust, mostly rainy, cloudy, snowy. any thoughts are appreciated
  12. Sep 21, 2012 at 9:41 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I had the airaid on my 06.. it was ok. It was the one that just replaced the primary filter.. but kept the stock seconday.. it still isn't better than a sealed intake tho..
    Honestly tho.. after having that one, then the AFE stage 2.. and now the gen2 TRD.. I would recommend the TRD intakes (1st or 2nd) or the afe stage 2 Si.. OR.. just stay stock. If you really want an intake. Make sure its sealed. I love my gen2 TRD intake and so glad I made the switch.
    Also, flat filters are going to be quieter than cone filters. Sealed will be quieter AND breath colder air than open intakes with just a heat shield.
    1st gen TRD intakes are cone filtered, 2nd gen TRD is flat filtered. Both are sealed and use the stock fender opening to draw in cool air.
    Hope this helps.
  13. Sep 28, 2012 at 12:34 PM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    If you don't mind me asking how much did the trd set you back? did you pick it up at the dealership or online?
  14. Sep 28, 2012 at 12:38 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I actually picked it up from a friend/member here. It threw codes on his, So he switched it out for a 1st gen trd.. and sold me it for $150. A great deal! I would still recommend it at full price tho. Keep an eye out In the fs section and online.
  15. Sep 28, 2012 at 12:54 PM
    #35
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Yea the more I look into it the more I'm finalizing the TRD. Ohio is way too wet to run a URD. Since my truck is new it is a little more reassuring to get a TRD. Although they haven't officially released a 2012 TRD CAI. Thanks for the feedback. Appreciate it.
  16. Nov 7, 2012 at 6:21 AM
    #36
    Roguesoldier13
    Roguesoldier13 New Member
    North Carolina
    2013 Tacoma TRD Sport
    Airaid Cold Air Intake, Wicked Flow Exhaust
    I bought a 2013 Tacoma TRD 4.0 and they do not have any CAI availible yet. I did some research and decided to go with an Airaid. Had to get one for a 2012. The install is almost Identical except for the air pump connection. The 2012 harness has 2 wires the 2013 has four you will need to splice in 2 extra wire harness extensions, its too easy. I am a new member so if I am beating a dead horse i apologize, just throwing this out there for any new 2013 Tacoma owners looking for an option.
    Installed the CAI and a 13" wicked flow to replace stock muffler.
    -noticed more throttle response, faster acceleration
    -MPG: 17.79 to 18.25 average change (keep in mind this motor only has 2000 miles)
  17. Nov 8, 2012 at 9:19 AM
    #37
    Two Tall
    Two Tall Well-Known Member
    Jim
    Ohio
    2018 TRD Off Road DCSB 4x4
    Retrax MXPro bed cover, Gentex Homelink mirror, TRD exhaust
    I'm debating on the Airaid since the TRD for 2012+ won't be available until next year at the earliest (per regular phone calls to TRD). Another member here states that the Airaid "squeals" on his 2012 at speeds over 60 mph. Please advise if you have the same experience.
  18. Nov 8, 2012 at 9:37 AM
    #38
    rclangelan
    rclangelan Well-Known Member
    Sykesville, MD
    2012 DblCb Baja Ed. (Black)
    TRD Front Skid Plate, Tacoma All-Weather Mats, BFG AT KOs (265/70/16)
    I had the TRD CAI on my 4Runner. It made my truck noisier and sucked more gas. That's it. I went from 17mpg down to mid 15s.
    The only good thing about it was that it looked cool (red) when you opened the hood.
    I won't be wasting my money on one of those again.
  19. Nov 9, 2012 at 11:48 AM
    #39
    Roguesoldier13
    North Carolina
    The Airaid intake does have a mild "turbo whistle" to it. I only notice it when the engine is under load ie fast acceleration. If you are looking for maximum performance and adding more power this intake will help some. As for MPG's hard to tell with the motor not broken in but as of yesterday I gained 2mpg. (Allowed for 2 weeks to access mpg improvement) That is with both the CAI and a muffler swap. which cost $420. So if mpg is your only motivation to install save your dollars. Hope this helps out.
  20. Nov 11, 2012 at 7:37 PM
    #40
    ogtay
    ogtay Member
    Orange County, CA
    2012 DC PreRunner TRD Sport LB Supercharged
    TRD Exhaust
    Been meaning to post for about a week now regarding the TRD CAI for 2012 and the news is not good. I go to SEMA every year for work and made a point of stopping by the TRD van and grilling them about the CAI. Talked to a TRD Exec for about 15 minutes and they said that they will most likely be pulling the plug on this project. They mentioned that there will be a new truck release and with only a 2 year window for the CAI that tooling up really does not make a lot of sense (understandable). They also have to get the harness approved by Japan for OEM warranty issues. They said they are trying but those 2 reasons make it a long shot. They Exec gave me their direct info and said they should have a final answer in the next 4-6 weeks but that the project was most likely going to be killed. I will update again when I have their final word on the matter.
