cold air intake for 2011/ 4.0v6 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smenglish, Mar 19, 2012.
  1. Mar 19, 2012 at 10:43 AM
    smenglish
    smenglish [OP] Member
    shawn
    beech creek,pa
    '11 trd sport metallic grey
    procomp black alloys on 265 75 16 bfg at's,ko's, 3" ready lift suspenion
    im looking to buy a cold air intake for my 2011 tacoma.its a tx-pro trd with a v6/4.0 auto 4door. im thinking an afe stage 2 cx kit with a pro dry filter or a afe stage 2 si kit with pro dry s filter. any ideas? the cx kit i think is a classic open filter and the si kit is enclosed filter box.
  2. Mar 19, 2012 at 10:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The Si would be better than the CX because it actually pulls cool air, not hot air from the engine bay.
    Check out the URD true cold air intake also if you're stuck on a CAI.
    Your stock intake is a cold air intake, one of the best, most cost effective things you can do would be to drop a high flow filter into your stock intake. AFE ProDry S is a popular choice.
  3. Mar 19, 2012 at 10:52 AM
    smenglish
    shawn
    beech creek,pa
    ive been looking at them for a little more power..i had one on my 09 2.7/4cyl tacoma and it seemed to help quite a bit going up steeper hills after i put it on.it was a k&n though.
  4. Mar 19, 2012 at 10:54 AM
    Pugga
    Massachusetts
    Don't mistake noise for power and the 4 cylinder is a little different from the V6. The V6's intake already draws cold air from the fender. Swapping it to the CX series would mean you're not drawing hot air from the engine bay. The Stage 2Si still draws from the fender so you might gain a little off of that but for the cost, you can't beat a good drop on on the 2nd Gen V6.
  5. Mar 19, 2012 at 11:29 AM
    smenglish
    shawn
    beech creek,pa
    thanks for the replies stil not sure what ill do yet though. maybe a drop in or the si..well see..
