cold air intake inside of cab?
Discussion in 'Performance and Tuning' started by xxOkieTacoxx, Oct 2, 2012.
  1. Oct 2, 2012 at 5:56 PM
    xxOkieTacoxx
    xxOkieTacoxx [OP] Well-Known Member
    Jake
    Texarkana, TX
    99 Tacoma SR5 3.4L 4x4/ 16’ DCLB TSS
    3.4L V-6 W/ custom intake,Flomaster super 44 dumped, 15" Incubus Alloy Wheels W/33x12.50 Yokohama Geolander MT'S, Bilstein 5100 Adj W/ OME 881coils, Pro Comp rear leafs W/ Bilstein 5100 shocks, Manual Hubs, Diff. Drop,Custom front bumper w/ winch W/ keyed disconnect and 2 250,000CP running lights, relocated blinkers, front bumper removed, radiator guards, custom skid plates, Rhinolined interior,
    Why couldn't someone pipe the intake into your cab? You would get colder air in the summer when you used the ac. Idk just a thought I've been pondering on. Opinions?
  2. Oct 2, 2012 at 5:57 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
  3. Oct 2, 2012 at 5:58 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    I have to say... that's a new one.
  4. Oct 2, 2012 at 6:00 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
  5. Oct 2, 2012 at 6:00 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    A friend of mine has this set up actually.
  6. Oct 2, 2012 at 6:01 PM
    TennesseeFan76
    TennesseeFan76 I intend to live forever. So far, so good.
    Phill Goodfactor
    Georgia
    2005 PreRunner DCLB
    3 inch lift, Debadged, 5% Tint, Custom Stereo, BHLM, Fog Light Mod, Sockmonkey Decals, OEM Bedmat, Plasti Dip Front Valence, Slims 6K HIDs (thanks goes to TheGloryFades), Hyper yellow fog lights, LED interior lights, Satoshi Grille with FJ Emblem, Pro Comp lights behind Satoshi, FatMat
    Just making sure I read that right!:facepalm:
  7. Oct 2, 2012 at 6:02 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    There's a member on here that actaully made one for his truck. Just go on the search thread and you'll find it
  8. Oct 2, 2012 at 6:02 PM
    no mods
    no mods Well-Known Member
    cincinnati
    Some stickers
    I've seen it done bit it was more for protection from water being sucked up during deep water fording.
    As far as ac to cool charge temps good theory but the intake volume from motor would be faster than ac output and would force you to open windows to keep from turning cab into vacuum.
  9. Oct 2, 2012 at 6:13 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
  10. Oct 2, 2012 at 6:17 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    it could definatly be done but the problem you would face is that the engine wouldnt get as much air flow as if it was in the front of the car. Also it would create a good size vacumn in the car is all the windows were shut.
  11. Oct 2, 2012 at 6:17 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  12. Oct 2, 2012 at 6:18 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  13. Oct 2, 2012 at 6:21 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
  14. Oct 2, 2012 at 6:22 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    You could run the exhaust into the cab in winter to preheat the engine intake air.
    Paint6it9black likes this.
  15. Oct 2, 2012 at 6:23 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Ah yes, the honda pop can exhaust.
  16. Oct 2, 2012 at 6:28 PM
    AlphaEcho2k5
    Adam
    Hurlburt Field, FL
    '02 4Runner
    at this rate you should really put a disclaimer...
  17. Oct 2, 2012 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    ive seen some race truck with the intake in the cab.
  18. Oct 2, 2012 at 6:31 PM
    Oscarbob
    Oscarbob Well-Known Member
    Bob
    Central New York
    '10 DCSB 4X4 OR, Pyrite Mica
    WeatherTec floormats and rainguards, Scanguage, LR UCA, 265/75/16 Duractrac's
    Semi relevant to the idea of using the AC system to cool the intake charge...
    From the 2003 Ford F150 Lightning concept:
    "The 32-valve supercharged engine uses patented ‘SuperCooler’ technology. Perhaps it should be called ‘SuperCooletti’ after SVT chief engineer John Coletti who both heads Ford SVT and patented the SuperCooler design himself. Coletti came up with a very practical way to provide a burst of power by using the truck’s air conditioning compressor to chill a small storage tank of coolant to 30-degrees Fahrenheit and then dump this coolant right into the supercharger’s intercooler with the touch of a button. The result is a 20% drop in air temperature that creates a higher density of air by volume for better combustion and higher horsepower - around 50-hp more for up to 30 to 40 seconds at wide-open throttle.
    Scarpello referred to SuperCooler as renewable nitrous oxide only much safer and regenerating. “The SuperCooler patent has been around for about 10 years,” according to Scarpello, “but it just hasn’t found the right application yet. It’s definitely production feasible and could be used across our entire line of vehicles.”
    http://www.pickuptrucks.com/html/autoshows/naias2003/ford/lightning2.html
  19. Oct 2, 2012 at 7:52 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    Couldn't you put the ac on fresh air to draw in more air, and also I have it designed on paper where I can disconnect the.connection and put it in the engine bay in the winter time. ( believe.me I already posed that problem). Idk I just thought it would be cool and plus it'd protect my cold air from water when.I go playing.
  20. Oct 2, 2012 at 7:54 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    Im an ammonia refrigeration tech and have been in the field of refrigeration for years. I bet I could figure out how to build a system like that pretty easily.
