Cold air intake issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by giostoner69, Apr 17, 2023.
  1. Jul 7, 2023 at 11:10 AM
    #61
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Deck plate mod!! Removing the fender snorkel in the old trucks/4rs was also the way to go. There was a guy that dynoed all the different combos and deck plate or snorkel removed plus amsoil filter was the best combo. I believe is increased 15 HP on the dyno. For real. Pair that with the supercharger and things got nuts.
  2. Jul 8, 2023 at 4:51 AM
    #62
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I can add this to the mix. If you use a tube like the HSI, be damn careful tightening the clamp at the factory air box. The outlet tube is very easy to crush/deform.
  3. Oct 2, 2023 at 7:15 PM
    #63
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    I drilled a 2 1/4” wide hole and stuck a coolant hose going through the sidewall, same side right next to the factory intake hose. Having drilled into the side wall myself, you want to pull the intake for more room.
    it pulls more of the same air through that tube instead of the engine bay. Keeping it cool.
    Basically a smaller second intake tube parallel to the stock one. Shouldnt really be a setback, might maybe notice a slight difference in pep.
  4. Oct 2, 2023 at 7:39 PM
    #64
    eurowner
    eurowner Duke Sky
    Scoty
    Coolant hoses are much hotter than ambient air temperatures…
  5. Oct 2, 2023 at 7:53 PM
    #65
    danny15l
    nada
  6. Jan 17, 2025 at 2:56 PM
    #66
    Moozer
    Moozer Member
    Dont listen to these neck beards hating on Rough Country. You didnt plug your sensor back in all the way is all.
  7. Jan 17, 2025 at 3:50 PM
    #67
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Solid first post
    RIX TUX, Chew, eurowner and 1 other person like this.
  8. Jan 18, 2025 at 11:44 AM
    #68
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    :101010:
  9. Jan 18, 2025 at 11:57 AM
    #69
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    WELCOME to TW
