Cold air intake issues (K&N) (P0171 code) "system too lean"
Discussion in '1st Gen. Tacomas (1995-2004)' started by $MoneyBagB, Jun 4, 2022.
  1. Jun 8, 2022 at 1:46 PM
    saint277
    saint277 Vigilo Confido
    Not really sure what your point is here, oiled filters screwing with sensors is a well known issue. As far as people being dumb, ya people are dumb, some even buy oiled air filters even though they give no benefit, give inferior filtration, and are known to cause issues. The op asked for help and a MAF sensor fouled by oil is a legitimate cause for that issue, not misinformation.
  2. Jun 8, 2022 at 1:48 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Whoa dude, chill. You came in strong suggesting that all K&N oiled filters are garbage. We are simply providing proof that K&N filters when oiled properly are not a problem. Obviously incorrectly / over oiled filters are likely to cause MAF sensor issues.
    It's just not a set-in-stone rule that K&N filters will coat the MAF.
    MalinoisDad likes this.
  3. Jun 8, 2022 at 2:01 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Group A understands.
    Group B thinks group A is crazy because they can’t achieve the same results. People will do what they’ll do.
  4. Jun 8, 2022 at 2:26 PM
    saint277
    Group A spent money on it and must justify there purchase
    Group B sees the data and understands all the possibilities
    treyus30 likes this.
  5. Jun 8, 2022 at 2:40 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    You made a blanket statement, and there is evidence that it's not the whole story. Doubling down on it isn't going to win you an internet award. No need for the group a/b tension.
  6. Jun 8, 2022 at 2:42 PM
    saint277
    HE STARTED IT ;)
  7. Jun 8, 2022 at 2:53 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I'd be shocked if the "first oiling" from the factory caused issues. From what I've seen the issues arise when the end user supersaturates at the first re-oiling interval. I ran a K&N for long enough to get past that first re-oiling and didn't douse the thing, and never had MAF problems. But my DIY expertise doesn't end after I put a box together with 6 pre-threaded screws either.
    Currygoat and MalinoisDad like this.
  8. Jun 8, 2022 at 2:58 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I would think it's similar in terms of logic to the don't change your transmission fluid if you haven't before. The customer probably gets a new intake / filter cause they have poor performance or maintenance issues, and then after that the light comes on. It's gotta be the intake, cause that's all the touched.. when it could more likely a be handful of other things which just happened to surface at that point.
  9. Jun 8, 2022 at 3:01 PM
    saint277
    Or it could be a fouled MAF sensor, due to oil being introduced to the system by an oiled air filter :cool:.
  10. Jun 8, 2022 at 3:06 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Love beating the dead horse don't ya?
    The OP said it happened after a day. The filter would have to be SERIOUSLY over oiled for the maf to get coated that quickly. So like I said originally:
  11. Jun 8, 2022 at 3:10 PM
    saint277
    :deadhorse:
  12. Jun 8, 2022 at 4:28 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
  13. Jun 8, 2022 at 4:38 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Do K&N Filters protect against 5g
  14. Jun 8, 2022 at 4:53 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Only if you oil them twice a month. Otherwise they amplify it
    Diablo169[QUOTED] likes this.
  15. Dec 21, 2024 at 4:48 AM
    #35
    Buckles2682
    Buckles2682 New Member
    Kevin
    Is your new air filter closer to the MAF sensor than it was before when the air box was there?.....I have a 2004 Escape that gave me a p0171 code after CAI install, and the only issue was my new filter was too close to the MAF sensor and it couldn't read all the air coming in properly as it's a lot more air a lot faster than with the box......it doesn't have to be exactly where the old filter was, but close to the same distance or further away.....preferably pointing directly at an air source coming in to your engine bay....I ran mine down to where the holes are in my bumper for the fog lights and pointed the filter right there and the code cleared itself......99% of the time it's something stupid.....just remember p0171 means unmetered air....so your problem will most likely always be right at the sensor or after it....but never before it....if you were having any kind of fuel deliver issues prior to installation, you may want to check that too as a weak pump or clogged fuel filter can throw the same code.....
  16. Dec 21, 2024 at 7:41 AM
    #36
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Now that it's two years later, pretty sure he solved the problem.
    Given that it threw the code after he put the K&N "CAI" in, it's pretty clear what the cause of the code was.
    2004Taco and Moonrman like this.
