Cold air intake kit thoughts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toyoncek, Apr 28, 2010.
  1. Apr 28, 2010 at 7:04 PM
    Toyoncek
    Toyoncek [OP] Member
    Ontario
    09 SR5 4x4
    Hey,
    Alright, so I have a 09 4x4 SR5 4.0L V6 Tacoma, and i'm looking at putting a cold air intake kit on it. Been looking around, but too many mixed reviews. Any thoughts?
    I do quite a bit of off-roading and pit mudding. Talked to a guy at performance improvements and told me an open filter vs. a closed filter wouldn't make a difference besides that I would have to clean it more. Would you guys suggest a closed box? As well, should I find a kit that would go into my fender, or just a plastic kit that would fit to a corner?
  2. Apr 28, 2010 at 7:13 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    save your money.
    if you want sound, add a muffler. i'm not really a fan of CAIs because they usually draw warmer air than stock systems and dog the first 3k of the powerband...
  3. Apr 28, 2010 at 7:15 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    The OEM system, in fact, IS a CAI so gains would be negligible. The only intake I've seen that has decent gains is the URD, but that involves cutting.
  4. Apr 28, 2010 at 7:27 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
  5. Apr 28, 2010 at 8:12 PM
    Toyoncek
    Ontario
    09 SR5 4x4
  6. Apr 29, 2010 at 8:06 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Take a look at the HP curves for any of these intakes, assuming you can find them, and ignore the peak HP claims. If you are a daily driver then you need to look at the curve to see if there are any gains in the RPM range that you drive at. From what I've seen, most of the reputable aftermarket, actual, CAIs only add HP after 3500-4000 RPM. If you don't spend a reasonable amount of time above this rpm range, you're benefit is strictly the for the sound of it.
    Look at you stock intake, it is a CAI. Now the air path can be improved by straightening it out, but again, those benefits only appear at the higher rpm ranges where those bends start affecting air flow to the TB.
    My opinion is that unless you want the sound, or the look, or the few HP that you gain at the high end of the rpm range, that it isn't worth it. I have the same opinion on cat-backs, they have a use, but are they worth it for your use? That's definitely your decision to make.
    BTW, in the interest of experimentation on something new, I am going to be attempting to plumb a Volant Air-Ram into the stock air filter housing to see if there's anything interesting there. Not going to dyno, but I'll be watching mpg's and I have a G-Tech to check for any performance gains. Ram air modifications don't tend to show up well on dynos anyway.
  7. Apr 29, 2010 at 8:21 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    I have to disagree with you there...i've got the TRD CAI (gen 1) and after i installed it i definitely felt an improvement in throttle response and my truck defintely got a couple more ponies...cause it accelerates a lot quicker and smoother after the intake was installed...:D
    it depends on what type of CAI you have...if its TRD or AFE or even the new AEM version for TRD (gen 2) you are pulling air from the fender...so its ambient air temp (same temperature that's outside)...
    it also doesn't dog the 1st 3K of the powerband...if anything it helps give you HP and some TQ...:D
  8. Apr 29, 2010 at 8:40 AM
    T0LLPHR33
    BSP TRD Off-Road
    yes i completely agree with you...only way to really tell if there is any HP/TQ gain in the powerband is to do it on a dyno...
    but the thing about dyno's is that there are way to many variables to take into consideration...you can have the same dynojet in 3 seperate parts of the city and I guarantee all 3 of the dyno's will read different #'s...
    dyno's #'s are a good way to see some gains...but even dyno's have their flaws...user and calibration flaws...
    i tell you this much...jump in my truck for a couple of pulls and then jump in your truck for a couple of pulls...you will feel an immediate difference...granted I am also running the X-1 and DTLH along with my TRD CAI...
  9. Apr 29, 2010 at 9:11 AM
    T0LLPHR33
    BSP TRD Off-Road
    yes a combination of performance definitely helps...
    but honestly I really felt a difference just with the TRD CAI...that was my 1st performance mod and drove around with that for a little over 9 months...then I added the DTLH which I felt the difference right away in the mid-top end of the powder band...but once i installed the x-1 I really felt an overall difference in the truck...:D
    honestly if you want a good performance part and don't mind spending the extra $$$ the APR X-1 unit is your best bet...not only does it give you better throttle response, more HP/TQ but its also self learning...once you drop the x-1 in...every performance part you install there after the x-1 will learn it on its own and adjust the tune for optimum performance...
  10. Apr 29, 2010 at 10:47 AM
    silver06pr
    silver06pr New Member
    eric
    spring lake, nc
    06 PreRunner SR5 V6, manual stock
    I had a Volant in my 06 PreRunner and noticed no differences in power and MPG. I Put the OEM equipment back in after a year.
  11. Apr 29, 2010 at 11:11 AM
    T0LLPHR33
    BSP TRD Off-Road
    all the volant intakes i know of...all made the MAF sensor read a shortage of air so it leaned out the engine...
    VOLANTS CAI in my honest opinion was made incorrectly...but that's just me...
  12. Apr 29, 2010 at 11:21 AM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    Anyone heard of an S&B CAI, it has a box around it, would that be better than just an open one? Or would it draw warm air too?
  13. Apr 29, 2010 at 11:24 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    IMHO our trucks stock are rich pigs, if I could find an intake that did lean out the truck in the normal operating range (cheat the MAF sensor) then I'd buy it for the MPG gains it would give you.
    S&B make some good products. I had one on my Nissan titan, not sure if its proven on the Taco yet. ALso the V8s seem to really wake up all around with an intake, not so much in a V6
    If your going for speed should have bought the Tundy. If your going for Mpg in an intake -drop in or we need to mod something better from our stock intake...like a hot air intake.
  14. Apr 29, 2010 at 11:40 AM
    T0LLPHR33
    BSP TRD Off-Road
    hot air intake huh...that defeats the purpose of having an intake entirely...the whole point to putting in an aftermarket intake is 1. to get rid of the carbon filter and allow more air into the manifold to create more power...2. you don't want hot air cause that will not make you more power...hot air will rob you of power...the more cold air you force into the intake manifold the more power you will create...that's why F/I whether or not turbo or supercharged job is...they push more air into the same manifold...the colder the better...to a certain point...too cold and you start running rich...but that's when we start talking about tuning the engine...that's a whole nother ball game...
    our trucks are really good on MPG and the speed well between a V6 and V8 that's like talking apples and oranges...we didn't buy a truck to do road courses and beat up on ferrari's...that's for sure...
    you want more MPG in a tacoma...change your driving habits...get a SG2 that way you can monitor the amount of fuel you are using in all gears whether automatic/standard...
  15. Apr 29, 2010 at 11:48 AM
    Pope953
    Wesley
    Asheville, NC
    SR5 Pickup
  16. Apr 29, 2010 at 11:52 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    save your money. they sound nice on manual trans but i think thats about it IMO. i feel like it actually decresed lower RMP power, kinda lags
  17. Apr 29, 2010 at 12:43 PM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    I got a scanguage - it tells me I have bad mpg and go fast. I drive like a gramma and still get 17mpg with 285s. The cold weather here in WI kills your MPg in the winter..i drop to 15 that sucks.
    I want to use it to help me to tune my engine to get better mpg. Some of the theories on this are a better Air fuel mixuture with hot air. I'm not into more poines on this truck, I went that way on my titan, don't really need it the way I drive it. I want 2 mpg more from some sort of modded hot air intake...enough of my rant. I need a stock airbox to gut :p and start testing!
    sorry for the thread jack. SAve your Cash for a supercharger if you want speed.
  18. Apr 30, 2010 at 10:53 AM
    Pope953
    Wesley
    Asheville, NC
    SR5 Pickup
    Yeah, I don't expect any gains really, maybe just a little bit of quicker throttle response, but thats a big MAYBE. All I really want it for is added sound. I plan to follow it up with a high flow cat, add on the breathing of my truck. Do you think that this would work??
  19. Apr 30, 2010 at 11:18 AM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Cold weather doesn't kill mpg, winter fuel does. Would feel bad if you were any place but WI. The farmers there are why we have ethanol blends.
  20. Apr 30, 2010 at 6:38 PM
    Pope953
    Wesley
    Asheville, NC
    SR5 Pickup
    Since the high flow cat is just a straight pipe would this, in theory, make my exhaust louder?
