Cold Air Intake - no haters please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingston73, Feb 13, 2013.
  1. Feb 13, 2013 at 9:02 AM
    kingston73
    kingston73 [OP] Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I've spent days reading through all the "intake" threads I could find so to start with, please don't respond by telling me not to get one, they destroy your engine, search the forum etc. Like I said, I've read through pages of threads but still have questions that I haven't found answers to.
    For those of you who have actually installed one and used one, I have a few questions.
    1. is the MAF calibration unit absolutely required for the 4.0?
    2. have any of you found it decreased mpg's at all?
    3. have any of you used more than 1 type? If so, did you like one over another and why?
    4. anything else I should know before I get one?
  2. Feb 13, 2013 at 9:19 AM
    acdronin
    acdronin Well-Known Member
    If anyone here bashes on you report it.
    Q#1: No, but, because CAI's change the way the airflows past the MAF sensor, it confuses the ECU into thinking there is more air going into the engine then there actually is. The MAF Calibrator intercepts the data from the MAF and changes it, thus 'correcting' it before it goes into the ECU.
    Q#2: Most definitely YES! Before I found this forum I was sold a bill of goods that my K&N 63 will improve power and increase MPG. The power gain was minimal and my MPG's went down by 2-3 MPG's. After discussing the problem with Gadget at URD, I purchased and installed the Calibrator which was mapped specifically for my K&N 63. The difference was immediate. The erroneous data from the MAF was causing the ECU to dump more fuel into the engine than it needed, hence it was running rich and wasting fuel. This also meant the truck was 'bogging down' under acceleration unless it was under wide open throttle. The Calibrator largely returned my MPG's pretty much back to where it was before.
    Bottom line, had I known all these things before hand, honestly, i don't think it was worth the hassle. To purchase the intake and then find out that you have a whole new set of issues is annoying. But in reality it is to be expected because you are altering the airflow dynamics of these computer designed engines and you end up with unforeseen issues. Yes, my truck is faster, it accelerates quicker and pulls harder than stock. It was just a PITA to get there.
    My understanding it the only intake that does add a 'substantial' amount of power is the URD CAI. This is the one which requires cutting a hole in the radiator frame to mount the intake in front of the radiator.
  3. Feb 13, 2013 at 9:21 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Thanks, that is one of the most useful posts on this subject I've read, appreciate the help.
  4. Feb 13, 2013 at 9:26 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    1. Not required but does give a nice little "open loop" kick. Yes, I have one.
    2. I've had an aFe drop-in, a Volant scoop tied into the stock airbox, an aFe Stage II SI, and a URD CAI, none of these affected mpgs any further then an assessment of right foot activities could account for.
    3. See 2 above for list. The dropin and the Volant setup just seemed like stock to me, no difference. The aFe had a nice tone to it at 3500 and above, but also had an irritating (to me...) noise at about 1500-2000 rpm, which is where most of my daily driving occurs, so I sold it. I have the URD CAI and the MAF Cali now, and they will stay as I like them.
    4. For daily driving I never noticed anything, 'cept noise, until I had the URD/MAF on at the same time. You get a little kick at about 3k and up that is different then stock or aFe alone. I ran some 1/4 numbers off of my G-tech for stock, aFe and URD (no MAF) and noted about a tenth better time for the aFe and the URD. I have not run any numbers with the URD+MAF combo yet.
  5. Feb 13, 2013 at 9:34 AM
    acdronin
    You're welcome, oh BTW, the Calibrator install requires that you solder 7 wires to the harness that goes into the ECU. Here's the trick, A: There are literally dozens of wires that feed into the ECU's five harnesses, it's a tight squeeze to find those wires and make absolutely sure you are working with the right ones. You will get a schematic with the unit. I checked all the wires three times before i started work. I did not want to screw this up. There is a plug n play harness that can be bought from URD but they are not cheap. B: 6 of those leads require a "Piggy back" solder, meaning you cannot cut the wires that you need to solder on to. Cutting the wires would alter the voltages and probably start throwing engine codes. It's one of those take your time, don't be distracted and make good and sure all the solders are good and heat shrink wrapped to avoid grounding.
  6. Feb 13, 2013 at 9:44 AM
    acdronin
    After all I have read and seen on these forums, it does sound like the URD combo is the best one out there for these engines.
  7. Feb 13, 2013 at 9:44 AM
    jamtoz
    jamtoz frog
    James
    Quebec
    trd sport DCLB 4x4 2014
    Duratracs, SCS sr8's, debadged
    any of you guys ran the aem bruteforce? just wondering if it makes a difference in mpgs and power. and with every CAI is it recomended to instal the MAF calibrator?
  8. Feb 13, 2013 at 9:48 AM
    acdronin
    I don't know anything about that one. But as far as recommended with the MAF? Depends on who you ask, there are folks that are not sold on it. But IMO, it seems to me that the guys at URD seem to have a very good understanding of what actually adds more to these trucks than just a lot of BRAAAAP.
  9. Feb 13, 2013 at 9:53 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    they do have plug and play harnesses for certain years, but they are more expensive than the MAF cal units now.
  10. Feb 13, 2013 at 9:58 AM
    acdronin
    Yeah, but from what Gadget says, they are a PITA to build which is why they are so expensive.
  11. Feb 13, 2013 at 12:04 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    ok thanks ;)
  12. Feb 13, 2013 at 12:19 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    One thing to realize about those MAF calibrators is it may not give you any benefit depending on how you drive. If you are a commuter, your truck will likely very rarely see open loop operation and, if so, for very short amounts of time. The MAF only makes adjustments in open loop mode. So for those of you looking for a CAI for MPG purposes, if you drive conservatively (like you should if you're trying to eek out good MPG numbers), then I really don't see the benefit of the MAF calibrator unless it's to correct the error codes that are common to certain CAIs.
  13. Feb 13, 2013 at 12:29 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Gadget has responded before and stated the maf cal does effect closed loop also....im not sure how much, but he def stated it is not only open loop dependent. It caught me by surprise also, and I have to try and remember that.
    Im on my phone, but ill try and link his quote when im on my pc later.
    Fwiw, I also had the afe stage 2 Si.....hated it past 3k rpm due to the resonating nature of it and the intrusive racket into the cabin....I damn near gave it away.
    Much happier with the urd and urd maf cal.....im not gunna make claims because I have not been on a dyno. I can say it is not intrusive, even at wot. Its got a mean growl inside, but its not nearly annoying or as loud inside. Outside tho, people def turn their heads.
  14. Feb 13, 2013 at 12:30 PM
    Pugga
    Massachusetts
    Hmmm.... good to know :)
  15. Feb 13, 2013 at 12:35 PM
    acdronin
    That's what I thought too, it does have an effect throughout the range.
    I love flooring it in tunnels (only briefly of course and not exceeding the posted speed limits :D). A couple of months ago there was a Harley with loud pipes in the lane next to me in one of the local tunnels, his shit was loud, I hit the pedal and he turned and looked at me.:)
  16. Feb 13, 2013 at 12:39 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    here ya guys go...........from Gman himself
  17. Feb 13, 2013 at 12:39 PM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    Good info! I've been seriously considering the URD MAF calibrator and plug-and-play harness (yes, it's more $$$ than the MAF itself, but I like the idea of not cutting into my ECU wiring and having the ability to completely remove it all w/out leaving a trace). With my TRD CAI (1st gen) and TRD cat-back exhaust, I'm not looking for drag strip performance increases in the rarely-used 5K RPM range on my daily driver. Rather, I am considering the MAF calibrator in order to maximize the efficiency/performance of my specific mods and (more importantly) to simply ensure my engine is operating within its optimal parameters. I've read that the truck's ECU is fully capable of adjusting the engine's settings into the optimal range for my mild intake & exhaust upgrades, but I'm not sure that's truly the case. I'm torn . . .
  18. Feb 13, 2013 at 12:40 PM
    acdronin
    Oh, I thought it was rich with the K&N 63
  19. Feb 13, 2013 at 12:42 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    keep in mind that these trucks run pig rich from the factory and I believe gadget found a free 15hp from a bone stock x runner, and a v6 camry just by using the maf calibrator..........and that guy does have dyno proof and access.
  20. Feb 13, 2013 at 12:44 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    wrong engine ;)
