Cold Air Intake? To install, Or not to install. That is the Question.
Discussion in '4 Cylinder' started by 4banger805, Aug 8, 2010.
  1. Aug 8, 2010 at 5:35 PM
    4banger805
    4banger805 [OP] Active Member
    Benjamin
    San Luis Obispo
    2005 Tacoma Prerunner 2.7L I4
    Just bought a 2005 Tacoma Prerunner, 2.7L I4, manny tranny. Curious as to what kind've mods i can do to get a bit more juice out of the 4 banger. I know cold air intake is one of the few quick/cheap mods you can do. I live on the Central Coast where it is quite foggy, and it doesn't get very warm. I'm not sure if a cold air intake would work, or if it would add any noticeable power increases. Any wisdom on this particular addition, or any other power increasing additions would be fantastic! thanks so much.
  2. Aug 8, 2010 at 5:39 PM
    chopper
    chopper ky taco
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    dura tracs, debadged, weathertech floormats, removed mudflaps,black paint wheels,k&n air intake.
    I put the cak on my 05 2.7 and it made a huge difference
  3. Aug 8, 2010 at 5:40 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2018 WRX
    what kind of gains are you looking for?
    a CAI really only benefits big engines 5.7+ or turbo'd cars/trucks a 2.7L i-4 will only see very small gains, maybe some more noise
  4. Aug 8, 2010 at 7:33 PM
    4banger805
    Benjamin
    San Luis Obispo
    I just want to get the most out of the 4cyl. I am not too engine savvy and am looking for some more "oomf" out of the 4 banger, because it ain't no V6. And i've heard one of the big issues with the 4cyl is that the xtra cab truck is too heavy. any way to reduce weight without getting rid of the SR5/Prerunner amenities?
  5. Aug 9, 2010 at 7:54 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Cai pulls air from the engine compartment. How is that cold? Stock pulls from the fender well, high pressuer, cold air.
  6. Aug 9, 2010 at 7:55 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    just remove the secondary air filter and drop in an afe pro dry s air filter
  7. Aug 9, 2010 at 8:04 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    The stock filter pulls air from a tube that draws air forced in from in front of the fender. However, the CAI filter is positioned so that this same tube is providing cool air from the outside, so it is certainly not any worse. Furthermore, they come supplied with a heat shield meant to shield against the warmth coming off the engine. This shield also touches the hood in an attempt to isolate the filter the best way possible. I agree that it is not a "cold air intake" in the sense that it is receiving cold air being forced in from the front like a race car would, but it is certainly not worse than the stock setup. One of the biggest advantages of a CAI is the high flow filter and less restrictive tube.
    My CAI made a difference in mpg and throttle response, particularly because I have a manual and can keep the power band where the intake makes the most difference...something that an automatic trans can't necessarily do. I also added a cat-back exhaust, but a muffler upgrade would have been sufficient, and I'm not entirely fond of the drone of the magnaflow.
  8. Aug 9, 2010 at 8:11 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    a CAI alone on a 4 banger won't do much of anything, i dont care what anybody says. if its power you want you should've bought a v6
  9. Aug 9, 2010 at 1:22 PM
    larryde09
    Larry
    Rochester, NY
    It does do something, albeit not much...K&N has the dyno charts to prove it. A CAI on anything won't do much, but a couple more horses out of a 4-banger is a big difference ;).
    In addition to the improved throttle response I previously mentioned, I track my mileage religiously and I gained ~2 mpg...therefore it paid for itself over the years. The cat-back in conjunction with the intake improved acceleration through the upper power band and gave another ~1 mpg...so combining upgrades does help, but the CAI by itself will do something!
    I do agree though: if it's horsepower you want, go can't beat a V6....with a CAI of course:D
  10. Aug 9, 2010 at 2:02 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Awesome noise maker. You will gain some in the right power bands and lose some in the bands you use the most if you are AT. Sounds cool though.
  11. Aug 9, 2010 at 2:14 PM
    4banger805
    Benjamin
    San Luis Obispo
    Yes, yes I know that if it's horsepower I was worried about I shoulda boughtthe V6. But that isn't the issue. I like the 4cyl, suits me just fine. I just want to squeeze all the "juice" out of it I guess. Who sells the best CAI? His easy is it to install? Aaand last but not least, whAts this "deck plate mod" I keep hearing about. How do i go about removing that secondary air filter? Where is it at? And can i just replace it before my next smog? Thanks guys
  12. Aug 9, 2010 at 2:18 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    you can always put the secondary back in...
  13. Aug 9, 2010 at 2:22 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    the 2 extra horse power still dosnt justify the $200 or more price-tag. unless you wanna go all out and put turbo's or something. your better off just leaving it stock.
  14. Aug 9, 2010 at 3:58 PM
    larryde09
    Larry
    Rochester, NY
    Possibly true, but it works great w/ my manual.
    I'm not sorry much worried about the 2 hp (it's closer to 7 at the top end, but that's not worth arguing), it's the mpg increase I'm interested in...it pays off over time.
  15. Aug 9, 2010 at 5:23 PM
    4banger805
    Benjamin
    San Luis Obispo
    Alright, so larry, you like the CAI. What brand/company did you buy yours from?
  16. Aug 9, 2010 at 7:19 PM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    I got an S&B CAI for my truck, hp boosts honestly there weren't any, but as far as MPG there was an increase. Mine has an enclosed box drawing air from the front of the truck, not the motor giving it true cold air. You could check it out. The only way you'll find out if it does anything is to do some research, find the one you want and put it on there. Instead of wondering...just my opinion thats what I had to do, I questioned it for a while but I just said screw it and bought one.
  17. Aug 9, 2010 at 7:22 PM
    larryde09
    Larry
    Rochester, NY
    Obviously you've seen people have different opinions on this topic. In my situation I tracked my mileage before and after an intake and I had an improvement...so for me, over time, it paid for itself and then some. I have a K&N but agree with wolfpack, you certainly run the risk of over oiling, I just make sure I keep the MAF clean...I've heard good things about the afe stuff.
  18. Aug 9, 2010 at 7:29 PM
    Pope953
    Wesley
    Asheville, NC
    SR5 Pickup
    Ya, I read way too much into it on TW. A lot of it is good information, and I figured its a gutsy call, but then I looked at it and said ah hell I'm looking for some extra noise, and something to blow money on, and if it helps then thats great. It ended up helping some so I scored. Might as well just get it and hope for the best.
  19. Aug 9, 2010 at 8:16 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    Bought one and put it on, took it off a month later. No advantage except it's pretty loud! I since bought an AFE Pro Dry drop in.
    Anyone need a slightly used CAI, I've got one to sell cheap.
  20. Aug 9, 2010 at 8:19 PM
    Pope953
    Wesley
    Asheville, NC
    SR5 Pickup
    What kind and what year model truck is it?
