cold air intake
Discussion in '4 Cylinder' started by Redfish, Sep 19, 2011.
  1. Sep 19, 2011 at 7:13 PM
    Redfish
    Redfish [OP] Well-Known Member
    My warranty is about to expire and I am looking at cold air intake and aftermarket air filters. I was told it would improve gas milage. Is this true?
  2. Sep 19, 2011 at 7:17 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    nope, no gain keep the factory intake and get a air filter (AFE Pro DryS) and remove the secondary filter, best gains you will get!
    Edit: If you have a first gen (pre 05) then search "deckplate mod"
  3. Sep 19, 2011 at 7:25 PM
    Redfish
    thanks, I have a 2011 2.7. Is there anything else I can do?
  4. Sep 19, 2011 at 7:31 PM
    Redfish
    can I get the pro dry filter from autozone or do I have to order online?
  5. Sep 19, 2011 at 7:34 PM
    Redfish
  6. Sep 19, 2011 at 7:37 PM
    08pretaco
    Oliver
    az
    Not really. You could TRY the URD MAF calibrator. Most 4 banger people do not buy it, you would be one of the first. Helps a lot of the V6 guys obviously because they have more room to work with as far as power and tuning goes.
    I would recommend trying out what I first suggested, removing the secondary filter and adding a Pro Dry S and go from there!
    Also look into a header, LCE or Doug Thorley (purchase through urdusa.com). Personally I have the DT so I am biased. I freaking love the LOW end performance I got out of it, hardly ever drive in high RPM range. Some people swear by the LCE, just comes down to preference I think. Either way I would also recommend that in conjunction with the intake situation.
    Everything should not run you too much:
    AFE filter ~ $45-55
    Link: $49 AFE Pro-Dry S Air Filters, AFE - Air Filters - Air Filters - Custom Fithttp://www.autoanything.com/air-filters/60A4151A0A0A3320744.aspx
    DT header ~ $407
    Link: http://www.urdusa.com/Exhaust-&-Hea...t_info.html?osCsid=3tpuuratdilvc64lf8lf68uuj7
    LCE header ~ $400
    Link: http://www.lceperformance.com/Doug-Thorley-Header-Kit-05-10-Taco-2-7-w-Air-Inj-p/1046080.htm
  7. Sep 19, 2011 at 7:38 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Lubbock Texas
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    I have a K&N, love it, no problems at all. And Volant, im thinking about selling my K&N for the volant CAI
  8. Sep 19, 2011 at 7:39 PM
    08pretaco
    Oliver
    az
    You also have a V6 ;)
  9. Sep 19, 2011 at 7:41 PM
    Redfish
    what do you consider high RPM range? Did you notice an increase in MPG? I would think the header would pay for its self. How difficult was it to install?
    Thanks
  10. Sep 19, 2011 at 7:41 PM
    06BLUEDBLSPORT
    Colin
    Lubbock Texas
    yeahhhhhhh see i dont check the topics people post their threads in lol, i should probably start doing that
  11. Sep 19, 2011 at 7:57 PM
    Redfish
    Well I am not looking for power just better gas mileage.
  12. Sep 19, 2011 at 8:10 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  13. Sep 19, 2011 at 10:06 PM
    08pretaco
    Oliver
    az
    Anything above 3k is high for me. Header really helps with the low end. And to the other member, forgot to quote, who said header, intake, exhaust wont make much of a mileage difference..I will respectfully beg to differ.
    I am pulling off 24-25 mpg with the way my truck is currently set-up. ~5" lift in front, 2" back, bumper/slider added wight, wheels/tires added weight, DT header, AFE secondary removed, 33.1" tires with 4.56 gears. I will have to say that I personally do not think I would be getting that mileage without those. Mind you the difference might be a scarce 1 mpg, but nonetheless.
  14. Sep 20, 2011 at 6:42 PM
    Redfish
    Thanks!
  15. Oct 18, 2011 at 7:11 PM
    YodasYota
    YodasYota I'm here for the chicks.
    Yoda
    Orange County CA/the Dagobah system
    White 2005 2.7L
    aFe pro dry s drop in, secondary air filter delete, "Black Box" mod, debadged, tinted windows, Hawaiian print all weather seat covers, rubber all weather floor mats, 300mm Broadway rear view mirror, hyper yellow headlights, surf wax melted in, on and around the bed (shes dirty), LED brakes, side markers, rear turn signals, license plate, and interior lights. A cracked tail light that I fixed with some tape, 235/75/15 All Terrains. $$$$NearFuture$$$ Alloy 15x8's, DT headers, upgrade speakers and head unit, THULE bed rack or a ladder rack. Than I think I'll be pretty satisfied.
    I actually came across an AFE pro dry filter at 4 wheel parts not to far from house. It came out to like $50 I think. I just hate waiting for online orders ha. I was shocked they had it for my truck and so were they.
  16. Oct 20, 2011 at 4:52 PM
    Redfish
    Ok Prodry is on its way and I am going to order the DT header. Does it come with gaskets and everything needed for the install? My mechanic will install it for $250.00. Did you notice an increase in MPG.?
  17. Oct 20, 2011 at 7:50 PM
    worthywads
    You will never get back your money on the exhaust since it will not save you any gas.
  18. Oct 26, 2011 at 5:16 PM
    Redfish
    So the header will decrease my MPG?
  19. Oct 26, 2011 at 5:23 PM
    worthywads
    Could, but they most certainly won't increase your mpg.
  20. Oct 26, 2011 at 5:33 PM
    Redfish
    If I am running lower RPM's I should use less gas? My mechanic replaced his headers on his V8 Titan and now gets 21 mpg. Just asking.
