Cold air intake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bmrandolph1s, Nov 17, 2015.
  1. Aug 19, 2016 at 6:44 PM
    #761
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Well technically, you wouldn't be able to over oil a paper filter
  2. Aug 19, 2016 at 6:45 PM
    #762
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Just guys I ran with back in Washington off the old WATTORA forums before they shut it down. 2-3 guys that were new to off-roading had them and we ran quite a few dusty trails and within a year or two they developed problems. After pulling the engines and replacing them they tore down their old engines and found scoring in the cylinder walls.
    redbull9944[QUOTED] likes this.
  3. Aug 19, 2016 at 6:45 PM
    #763
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    ‘24 LC250 First Edition, ‘25 TRDOR 6MT, 2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    I've heard about people over oiling their filters. Maybe it has to do with the area and terrain their driving on? We don't have much dust here in PA. I have friends that are certified techs that run K&Ns with no issues.
    Maybe that's the cause if they're always out stirring up dust. Would also make sense that if they do clean their filters themselves because of all the dust, they are over oiling them.
    Aussiek2000[QUOTED] likes this.
  4. Aug 19, 2016 at 6:46 PM
    #764
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    You can absolutely over oil a K&N filter. You can also run the engine too quickly after oiling which is common because people don't know how to read instructions. Not to mention common sense is not common, sadly.
    OneWipeCharlie and redbull9944 like this.
  5. Aug 19, 2016 at 6:49 PM
    #765
    redbull9944
    Southwestern PA
    @Aussiek2000 I forgot to mention, but I know they also make filter covers (as dumb as that sounds) to cover up the outside of the K&N filter and perhaps make it more resistant to dust? I've never used one. Maybe you're familiar with them?
    Edit: Here's a link http://www.knfilters.com/search/wrap.aspx
    Seems this is specifically used for filters that are exposed to especially dusty environments.
  6. Aug 19, 2016 at 6:51 PM
    #766
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Over oiled filters usually end up with fouling on the MAF sensor which causes either a lean condition or rich condition on the engine which ultimately leads to long term issues with the engine.
    redbull9944 and Aussiek2000 like this.
  7. Aug 19, 2016 at 6:54 PM
    #767
    redbull9944
    Southwestern PA
    Just read the instructions and pay attention when you're servicing your filter and you should be golden
  8. Aug 19, 2016 at 6:54 PM
    #768
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    If an independent dyno shows 2 or 5 or 15 hp great.
    I drive and sometimes race my fairly warmed over 360 in my Challenger at Bandimere a mile up and can verify the loss of HP with thin air at this altitude. The guy planning on doing the dyno test is at my altitude. That's why I warned that comparing a head to head dyno run at this altitude will likely show less gain than at sea level.
    But some here say if you don't own a 3rd Gen, shut up, as though physics changed in 2016.
  9. Aug 19, 2016 at 6:57 PM
    #769
    redbull9944
    Southwestern PA
    I just don't see why anyone would spend the money to dyno a mid-size truck that could gain 5hp max haha. You want an independent dyno so that's what you're relying on. This isn't a sports car forum, it's going to be hard to find a guy that wants to pony up money for something stupid like this.
  10. Aug 19, 2016 at 7:00 PM
    #770
    2016 Tacoma SR
    HOCO Maryland
    You're right, you will make less power at higher elevations. Your truck will also make less power in stock form though so the base line pull is also skewed. I have to assume not every dyno pull comparison video is done at sea level. Truth is, anyone that believes the 17 HP gain BS should buy my bridge, i'll sell it real cheap. Anyone with half a brain knows the increase will not be significant, but it will be something and they do generally sound good while doing it.
  11. Aug 19, 2016 at 7:00 PM
    #771
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    That's what I consider expecting a lot from an average consumer vice enthusiast.
  12. Aug 19, 2016 at 7:02 PM
    #772
    2016 Tacoma SR
    HOCO Maryland
    Then they get what they deserve. If you're too stupid to properly clean and oil a filter, you probably shouldn't be allowed to operate the vehicle said filter came out of.
    opentang likes this.
  13. Aug 19, 2016 at 7:02 PM
    #773
    worthywads
    We already found the guy. haha
    2016 Tacoma SR likes this.
  14. Aug 19, 2016 at 7:07 PM
    #774
    redbull9944
    Southwestern PA
    This would eliminate 75% of drivers on the road
  15. Aug 19, 2016 at 7:07 PM
    #775
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Ultimately it comes down to Toyota has designed the engine around the stock intake and exhaust. It's a naturally aspirated engine which means there's going to be "pulses" in the intake and exhaust system. Adding an intake to the system without tuning the engine is going to disrupt the design of the system. Changing the parameters of on part of they designed system will result in a change in another. I'm going to guess and say that changing the intake is resulting in a more rich environment for the engine which is why people are seeing the HP and torque gains.
  16. Aug 19, 2016 at 7:08 PM
    #776
    redbull9944
    Southwestern PA
    Sweet. I hope he follows through
  17. Aug 19, 2016 at 7:09 PM
    #777
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    You're being generous, id say 99% of the drivers.
  18. Aug 19, 2016 at 7:09 PM
    #778
    redbull9944
    Southwestern PA
    Sad but true
  19. Aug 19, 2016 at 7:10 PM
    #779
    2016 Tacoma SR
    HOCO Maryland
    Here in MD, that would be a good thing. I've traveled quite a bit, MD drivers are some of the worst in the country.
    redbull9944 likes this.
  20. Aug 19, 2016 at 7:12 PM
    #780
    redbull9944
    Southwestern PA
    It's just O2 level isn't it? Correct me if I'm wrong but the ECU is more than capable for adjusting to the new level of intake. If you take a truck straight out of Louisiana at sea level and drop it in the mountains of Colorado it'll adjust to compensate for the change in O2
