Cold Air Intake?
Discussion in 'Performance and Tuning' started by Krystal32490, May 4, 2016.
  1. May 4, 2016 at 10:30 AM
    Krystal32490
    Krystal32490 [OP] Member
    KPuff
    What would be the best cold air intake to put on a 2010 V6?
    I guess they give you better gas mileage, correct?
  2. May 4, 2016 at 10:32 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    I went aFe, not really a change in gas mileage haha, makes cool noises though!
  3. May 4, 2016 at 10:34 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    Oh no you didn't!:eek:
    (Listen between us, I'm gonna give you a tid bit of info; don't bring up cold air intakes.)
    But the answer is no. Cost vs. result is basically nothing. And technically an aftermarket intake makes a "hot air intake". The factory one on the truck is in fact....a cold air intake.:hattip:
  4. May 4, 2016 at 10:35 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Stock is a cold air intake and, other than sound, going aftermarket is going to either change nothing or make it worse. Your engine was well designed from the factory.
  5. May 4, 2016 at 10:37 AM
    Chesh
    Chesh Well-Known Member
    The one that came with the truck from the factory that doesn't pull hot air from the engine compartment or suck up dirt, sand, dust, and other shit due to an open design to make it sound cooler.
  6. May 4, 2016 at 10:37 AM
    Nighthawk
    Levi
    Casper Wyoming
    aFe pulls air from the same place as the stock, its still cold air, just has a filter with more surface area.
    Aw9d and Torspd like this.
  7. May 4, 2016 at 10:38 AM
    digitaLbraVo
    So it breathes worse, is what you're saying?
  8. May 4, 2016 at 10:39 AM
    Nighthawk
    Levi
    Casper Wyoming
    Why would it breath worse if it has less air restriction than stock?
    grubburg, TreyStewart and Torspd like this.
  9. May 4, 2016 at 10:40 AM
    digitaLbraVo
    How does it have less air restriction if there is more filter media to pass through? Does it modify friction as well as sound bitchin'?
  10. May 4, 2016 at 10:41 AM
    Nighthawk
    Levi
    Casper Wyoming
    If the thickness of the media had increased as well, I would say you have a point. But an increase in surface area does not imply an increase in filter thickness.
    Mr.PowerTrays and Torspd like this.
  11. May 4, 2016 at 10:43 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Mine pulls from oem spot and is enclosed and has a non-oiled washable filter but you would need 2 intakes and a different filter to make it tho.....and it sounds cool too
    KVA...........K&N tube, Volant box with clear lid, AFE Pro Dry S filter
    Pipe insulation rolled up around and zipstripped to intake tube inside box against back of filter keeps the hot engine bay air out and allows for engine movement - no static connection to filter box.............
  12. May 4, 2016 at 10:43 AM
    Hondah
    Newnan, Ga
    '13 RC 4x4
    OP do you see what you've done! :facepalm:
  13. May 4, 2016 at 10:46 AM
    digitaLbraVo
    If the engine is going to intake what it needs (and the stock one is sufficient) what good does increasing filter media do? Additionally: if the filter flows better that means more undesireable is getting into the intake.
  14. May 4, 2016 at 10:49 AM
    Chesh
    To be fair, most Tacomas I've seen on the road seem to be Barbie trucks accessorized with useless shit designed to look and/or sound cool instead of actually doing anything useful, so it's not a terrible question in that regard.
    digitaLbraVo likes this.
  15. May 4, 2016 at 10:49 AM
    Nighthawk
    Levi
    Casper Wyoming
    I'm not exactly sure how I can explain any better. Unless you also have a degree in mechanical engineering and have studied fluid dynamics I don't think we are going to see eye to eye haha.
  16. May 4, 2016 at 10:59 AM
    digitaLbraVo
    So you agree I'm right?
    Well at least we've resolved that one.
  17. May 4, 2016 at 11:04 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Leave it as is. I will be buying the AFE dry drop in filter only, because my air filter needs to be replaced anyway and I'm sure the lifetime warranty will save me $ in the long run.
  18. May 4, 2016 at 12:32 PM
    Nighthawk
    Levi
    Casper Wyoming
    Cant argue with that logic haha. Straight out of the 3rd grade book of witty responses. I suppose if I stuck around long enough you would probably call me a "butthead" and use the phrase "I know you are, but what am I?" repeatedly.
    Mr.PowerTrays and Mully like this.
  19. May 4, 2016 at 12:41 PM
    ABA180
    East Bridgewater MA
    I am rubber..you are glue. Whatever you say to me bounces off me and sticks to you!
  20. May 4, 2016 at 1:01 PM
    digitaLbraVo
    Actually if you look at the post progression you attacked my credibility first. You also haven't made a point beyond claiming you "know about it" without providing any proof. If the stock intake is sufficient what does making any changes to it do for you beyond change the sound? (Which is what I said earlier.)
