Cold Air Intake????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GeoTaco, Jul 7, 2009.
  1. Jul 7, 2009 at 7:52 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    well when i did this mod to an 06 matrix, it rough ideled for like 10 minuetes at a stop sign then it corrected itself. so toyota must have put them in all their vehicles after 05 for emissions standards
  2. Jul 7, 2009 at 7:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    :rofl::rofl::rofl::burnrubber:
  3. Jul 7, 2009 at 8:37 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    The OEM system IS a CAI.
  4. Jul 7, 2009 at 10:47 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    The OEM intake it came with is (in most cases) going to be the best - sounds crazy but here's the real deal -
    The reasons anyone makes a "cold air intake" are:
    1) To sell you something that "looks cool" and makes noise (keywords - sell you something).
    2) Because "Fast & Furious" was just such a cool movie and "you gotta be like them, dawg".
    3) You'll think your ride is that much better than the next one just like it (they made thousands of em).
    Now back to the real deal -
    Most "cold air intakes" are misleading to begin with. If the filter is an open element (you can see the filter) and it's under the hood, it is actually a "hot air intake" (in other words - they lie and sell you something). When was the last time you ever felt a cool breeze under the hood of a car/ truck? A true cold air intake has to take in air from an ambient source - aka outside the engine bay. If you want one that bad for the "cool factor", or if your car/ truck doesn't breathe from outside the engine bay, find one that fits that description.
    The air that the OEM (the one it came with from the factory, or Original Equipment Manufactured) air intake breathes in is usually from just behind the grille itself, or sometimes from a fenderwell. This "air charge" is actually cold (or ambient temperature air), as hot air will just drop your ignition timing (because of pre-ignition or detonation) as the temperature of the intake air increases, and take all your HP with it.
    Let common sense help some on deciding just how good an aftermarket part or system is:
    1) Why would the Manufacturer short you on the performance it could have for an extra $100?
    2) If you gained MPG with a simple piece of tubing and a "one size fits all" air filter element - wouldn't they do that at the factory that built the vehicle?
    3) Who do you think has more money and resources for Research and Development - the company that designed and built the entire vehicle, or the company that made that "cold air intake"?
    4) If something you could buy and install yourself would actually add HorsePower and MPG, why would any vehicle manufacturer waste millions designing it the way they did (and lose the edge on the competition)?
    Add to that the water protection that a stock OEM air box is designed to provide. Water intrusion is a HUGE concern to prevent damage, and here's the reason, air compresses and water doesn't. If an engine breathes in water, and tries to compress it, it will break in a big way.
    Some "cold air intake" kits have a water intrusion valve that is basically a ping-pong ball in a sleeve - good luck trusting an engine to that. I know where they got the R&D on that design, just open up a wet/ dry shopvac and you'll see the same thing. Amazing how brilliant these things are when you dig.
  5. Jul 8, 2009 at 6:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Well said!! ^^^^^^^^^^^^^^^
  6. Jul 8, 2009 at 6:30 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    i think the biggest thing a Ram air intake for our trucks mainly provides is a better breathing filter element and thats where the bigger tubes and such are for, easier air induction.
    Also these intakes do show gains on a dyno, yes they are on the top end way up the rpm range but gains are received
    I think that even though the air that the stock box gets in our trucks is from the wheel well, the air filter is in a box sitting in the engine compartment
    So the cold air has to run through a hot air filter before entering the engine
    thats just how i feel
  7. Jul 8, 2009 at 6:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    In many cases the intake hose on an aftermarket CAI is smaller in diameter, then the OEM. I have only seen 1 "CAI" (TRD) that has given a gain, and it was only 3 hp. Gadget has dynoed his higher, but given that they cant filter all the dust out of the air ( in AZ) and they really have no gians, Im not a fan of them.....
  8. Jul 8, 2009 at 6:43 AM
    Burgman
    Stephen
    Ric VA
    i know how u feel about CAI chris, but my K&N filter def. has a larger intake tube....
    and when i get on it be it sound or actual gains my butt dyno thinks its better, so butt dyno FTW
  9. Jul 8, 2009 at 6:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, The K&N does have a larger tube, than OEM......As long as the butt dyno is happy. :)
  10. Jul 8, 2009 at 6:56 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    There are only 2x things you can really do to the V6 intake as its already a pretty solid cai. Replace the filter element with something that flows better like a TRD, Green filter,or a K&N. Another thing that hasn't been done that would help would be to replace the ribbed hose that goes into the fender with a smooth aluminum tube. The ribs on the hose create air turbulence which will affect flow rate.
  11. Jul 8, 2009 at 6:59 AM
    GeoTaco
    GeoTaco [OP] the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    so out of the drop in air filters, is there a better one, or are the all pretty much equal? I really only know about K&N because i hear more about them
  12. Jul 8, 2009 at 7:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It doesnt affect the air flow as one may think. Much like the tail gate of a truck being "UP", the ribs have little swirling ait pockets, that actually aid the air flow.
  13. Jul 8, 2009 at 7:55 AM
    jla888
    jla888 Well-Known Member
    the afe stage 2 for the 2.7 will give you better top end and a lot more noise. i have one for sale mint w/ an unopened afe filter cleaning kit.
  14. Jul 8, 2009 at 8:20 AM
    beastlytaco
    Ian
    08 Access Cab SR5
    the pro dry S filter doesnot require oiling and therefore doenst give you a chance to screw up the MAF sensor with over oiling. its washable.
  15. Aug 5, 2011 at 8:07 AM
    #35
    ufgatrs82
    ufgatrs82 Member
    SC
    11 Prerunner Trd offroad
    Bakflip F1
    Im a little confused. AFE website claims 13hp gain but there are many comments on here that state they don't do anything? Help?
  16. Aug 5, 2011 at 9:18 AM
    #36
    JKD
    JKD Well-Known Member
    I think these are valid points, however it is good to remember that OEM engineers have to think about a variety of issues when designing an air intake--especially noise and packaging. Their designs are a compromise between flow, silencing, cost, and packaging. Aftermarket manufacturers can safely discard silencing, and often can be more flexible about packaging and less concerned about cost.
    In my previous vehicle, one company did engineer a fantastic, well designed CAI that really works. The reason it was so good was that the factory intake drew in under-hood warm air, had lots of bends and turns, and was designed to be as quiet as reasonably possible. There was room for lots of improvement performance-wise. The CAI required a little modification to the engine bay and didn't care about sound--only performance. For those of us that bought them, that's what mattered.
    Now, the Tacoma's factory CAI, as far as I can tell, is well-designed from a flow standpoint. Look at the size of the filter area! Look where it draws in the intake air! There is very little performance gain to be had in redesigning the air intake on this vehicle.
  17. Aug 5, 2011 at 9:30 AM
    #37
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    The intake definitely helps on the 4.0 engine. Now I can't say it gives 13hp, but it definitely made a difference in my truck and I switched from a k&n drop in to the afe cai.
    I don't understand why people continue to say they don't add power?
  18. Aug 5, 2011 at 9:31 AM
    #38
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you will NOT gain 13 hp with a CAI.
    maybe a couple ponies. but not over 3.
  19. Aug 5, 2011 at 9:31 AM
    #39
    97yota4wd
    Eric
    Mesa, AZ
    they increase sound, and alot of times they "feel" like they increase power cause of increased sound. chris 4x4 has done dyno tests with no results
  20. Aug 5, 2011 at 9:37 AM
    #40
    TacoSupreem
    Hayden
    Kentucky
    Mine isn't loud cause it's in a box. Well just cause one truck didn't see a gain doesn't meen they all won't. All dyno's are different too.
