Cold air intake
Discussion in 'Performance and Tuning' started by 2004tacoma4x4, Jan 29, 2017.
  1. Jan 29, 2017 at 7:03 PM
    2004tacoma4x4
    2004tacoma4x4 [OP] Member
    Rogan
    2004 silver double cab Toyota Tacoma trd
    4 inch lift rolling on 295's
    Where would the best place to buy a cold air intake be?
  2. Jan 29, 2017 at 7:06 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Don't...
    757yotas and devinzz1 like this.
  3. Jan 29, 2017 at 7:28 PM
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    I bought a K&N at o'rileys for mine. Bout 300 bones and a hour of your time.
  4. Jan 29, 2017 at 7:30 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    stock is best with these trucks.
    757yotas likes this.
  5. Jan 29, 2017 at 9:32 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Look up the deck plat mod if you really want something similar to a cold air intake. Cold air intakes on our trucks are actually "warm" air intakes due to it sucking air from under the hood and not outside the truck
  6. Jan 30, 2017 at 1:00 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yes, dont get anything! Literally anything aftermarket that is advertised as a CAI is infact a "hot air intake!" The stock unit is as cold as you'll ever have on your truck! If you want more air flow get a better flowing stock drop in filter. Some guys will also cut the 90° elbow out of the duckting that goes from the air box to the fender, but i question how much that actually increases flow. There are a handful of aftermarket drop in filters that give a bit better air flow, that will be your best option for added flow while actually keeping cool air being sucked into the intake my man!
  7. Mar 10, 2017 at 4:14 AM
    coolreed
    coolreed Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    I agree with bry838. I use a drop in K&N Air Filter. I took a look at the stock Toyota Air Shroud and it looked very well designed. So I stuck with it.
