Cold AIR INTAKE
Discussion in 'Technical Chat' started by bowzerdoo77, Jan 27, 2007.
  1. Jan 27, 2007 at 6:10 PM
    bowzerdoo77
    bowzerdoo77 [OP] U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    I have a question has anyone heard anything about the any problems with the mass air flow sensors if you put a K@N FIPK cold air intake on your truck? I have heard the oil might have something to do with it if anyone has one on their truck and has or hasent had problems will you let me know thanks.. if you have a diffrent kind of intake or if anyone knows if TRD makes one let me know ok
  2. Jan 29, 2007 at 5:20 PM
    jskicet
    jskicet Member
    Go with the TRD, you'll be thankful later. Fit and finish is unmatched.
  3. Jan 29, 2007 at 10:04 PM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    a lot of people like the trd intake, if you use the k&n just clean your MAF sensor periodically.
  4. Jan 30, 2007 at 7:30 AM
    quiksilvr06
    quiksilvr06 Member
    Need to do some upgrades, and need some input on where to go w/ COLD AIR Intakes... anyone got any suggestions?
  5. Jan 31, 2007 at 6:31 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    TRDUSA.com doesent list a cold air intake for a 2004 do I need to look somewhere else to get one?
  6. Feb 1, 2007 at 3:57 PM
    jskicet
    jskicet Member
    Same yourself some money, and just do the "deckplate mod" on the 04. Works great on my 01. Easily reversible if you don't like it, but I know you will. You definetly feel the difference in the 3000 to 4000 rpm range.
  7. Feb 2, 2007 at 2:17 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    what is a deck plate mod?
  8. Feb 2, 2007 at 3:29 PM
    jskicet
    jskicet Member
    Just search on google. Basically your cutting a 4 inch hole in the front of your stock airbox. You go to a boating store and purchase a deckplate and install it over the hole so you can seal it off when offroading through water, here check this out
    http://www.trdoffroad.com/articles/deckplate/index.php
  9. Feb 2, 2007 at 8:13 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    Thanks I will try that sounds simple to do
  10. Feb 3, 2007 at 4:59 PM
    twoarezee
    esco, ca
    00 Dropped Mini
    deck plate for sure, i live in socal and never leave the road so i just cut a hole in the box.
  11. Feb 3, 2007 at 6:03 PM
    bowzerdoo77
    North Ogden Utah
    1997 REG CAB 4x4
    None
    Funny as at may sound I dont ever leave the road either, maybe a dusty dirt road every now and then but no mud and all that crap for me. It snows where I am from thats the reason for the 4WD not to beat it up and get stuck..
