Cold air intake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joey07, Jul 27, 2021.
  1. Jul 27, 2021 at 8:59 AM
    Joey07
    Joey07 [OP] Member
    Joey
    2021 Toyota Truck Tacoma SR 2WD 2.7L
    I have a 2021 sr 2.7 Tacoma. Was looking for a cold air intake but all say don’t fit my 2021. Any suggestions? Also as a starter any cool suggestions on mods? Currently had all terrain wheels with running boards no mods thanks in advance
  2. Jul 27, 2021 at 9:06 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Pretty sure 16-21 is all the same. Unless they did some sneaky redesign to the engine but i dont tink so
    Skydvrr, Joey07[OP] and Benny blanco like this.
  3. Jul 27, 2021 at 9:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    You know your truck has a factory CAI, right?
    What are all terrain wheels?
    An OE bed mat and under rail bed lighting by @mattgecko are useful mods.
    If you live in salt country properly protecting your frame would be 1st up. It may not be a 'mod' but it is essential.
    shakerhood, Lt. Dangle, Chew and 5 others like this.
  4. Jul 27, 2021 at 9:33 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Welcome aboard, Joey
    Joey07[OP] likes this.
  5. Jul 27, 2021 at 9:37 AM
    Joey07
    Joey07 [OP] Member
    Joey
    Thank you
  6. Jul 27, 2021 at 9:40 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Judging from numerous posts on TW, CAI is not worth the cost and fails to provide any significant benefit.
  7. Jul 27, 2021 at 9:41 AM
    Joey07
    Joey07 [OP] Member
    Joey
    Thank you
  8. Jul 27, 2021 at 9:42 AM
    Joey07
    Joey07 [OP] Member
    Joey
    thank you, these are all terrain tires as opposed to basic stock tires
    Junkhead likes this.
  9. Jul 27, 2021 at 9:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Supposedly for the 2.7l, pulling the secondary charcoal filter helps quite a bit. It is only there to absorb fuel fumes when the truck is not running.
    shakerhood, Junkhead, hiPSI and 2 others like this.
  10. Jul 27, 2021 at 9:49 AM
    Joey07
    Joey07 [OP] Member
    Joey
    Thank you and it what ways do you think it might help? Or from what you heard. Thanks again
  11. Jul 27, 2021 at 9:52 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Supposedly more throttle response and a bit of torque. There are some threads around here about it.
    The 3.5s have them also, but don't see a much benefit from removing it.
  12. Jul 27, 2021 at 9:53 AM
    Joey07
    Joey07 [OP] Member
    Joey
    Awesome. Will def try out. Thank you
  13. Jul 27, 2021 at 9:53 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    :cheers:
    Tacospike likes this.
  14. Jul 27, 2021 at 9:53 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Welcome aboard. Check out the LCE header. It's good for a few hp and tq
    ozpall likes this.
  15. Jul 27, 2021 at 10:05 AM
    Joey07
    Joey07 [OP] Member
    Joey
    Will do. Thank you
  16. Jul 27, 2021 at 10:15 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    If you live in a overly strict emissions state, (CA) I wouldn't mess with this.
  17. Jul 27, 2021 at 10:17 AM
    Joey07
    Joey07 [OP] Member
    Joey
    Texas
  18. Jul 28, 2021 at 6:53 AM
    LTG4087
    LT
    DFW
    2019 TRD Off Road
    In Texas, you still have to get a yearly inspection (after first two years from new) where they do check emissions. Don't know if removing that filter would be detected but I guess if you failed, it could be replaced.
  19. Jul 28, 2021 at 7:44 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Most stuff for Tacoma that's sold by Amazon says it won't fit. I got the 3.5 v6, I installed a K&N and I replaced the air intake plastic part that goes from the air box inside the fender with the TRD version, I believe it's called Air intake Accelerator..., presto CAI for cheap!
  20. Jul 28, 2021 at 7:46 AM
    jeremyv821
    jeremyv821 Member
    Jeremy
    Queensbury, NY
    2021 Voodoo Blue TRDOR 6AT
    Link
    link please?
